David George 1 | 01/08/2019 07:47:05 |
![]() 2110 forum posts 565 photos | I needed a knurling tool to knurl a 2 inch diamiter knob a few weeks ago and my M Type Drummond lathe isn't strong enough to use a push type tool and ended up getting if done on a friend's lathe. I had a think and thought I can make one to use on my lathe and here is my efforts. I had bought a push knurling tool at the Doncaster show and robbed it as it had three pairs of wheels in and only cost £10.00. The screw was a 130 mm long capscrew and a spring to support the top arm in a rough set place. There is a bronze washer to help the spring slide and a bent 6mm washer at tbe top of the spring to help it slide over the bolt slot. It works very well. David
Andy Carruthers | 01/08/2019 09:19:07 |
![]() 317 forum posts 23 photos | Thanks for showcasing your knurling tool David, your design may very well solve an issue as I am considering making a new knurling tool myself |
larry phelan 1 | 01/08/2019 16:12:42 |
1346 forum posts 15 photos | I made a knurling tool some time ago, not nearly as good as yours, but same type, mainly because I did not like the push type. I think they are too hard on the lathe, much better to operate under and over. Looking at your model, I am tempted to make something like that to replace my rough and ready unit. Very nice job ! |
David George 1 | 01/08/2019 18:06:12 |
![]() 2110 forum posts 565 photos | I have finnished it and oil blacked it and here is a picture now. David
Plasma | 02/08/2019 06:47:36 |
443 forum posts 1 photos | Nice job, very similar to the one I use and so much easier to control depth of knurl etc. Plasma |
