Rod Ashton | 21/07/2019 15:16:17 |
344 forum posts 12 photos | I am using a "Quick Step" Milling Unit as a router on my CNC. The unit is getting very hot and I wondered if anyone would know about lubrication in the gearbox. I have no manual of any kind. If anyone has knowledge of these units, I would be most grateful for any advice. |
Baz | 21/07/2019 15:25:12 |
1033 forum posts 2 photos | As Hemmingway sell, or used to sell these units it may be an idea to contact them. |
Michael Gilligan | 21/07/2019 16:39:23 |
![]() 23121 forum posts 1360 photos | That nice chap Stub Mandrel lists four items in 1998, here: **LINK** http://www.stubmandrel.co.uk/images/Bits_and_pieces/MEW_Index_Issue_01-237.pdf I haven't checked, but there may be something there about lubrication. MichaelG. |
Enough! | 21/07/2019 16:44:14 |
1719 forum posts 1 photos | Posted by Baz on 21/07/2019 15:25:12:
(Though interestingly Hemingway now have a complete Quorn kit). |
ega | 21/07/2019 17:25:53 |
2805 forum posts 219 photos | My QSM gearbox and motor do heat up under prolonged use but not so much as to cause me concern. I only ever use the machine in horizontal mode and I wonder whether you are running yours with the spindle vertical which might well make a difference. I think the motor is continuous rated but perhaps not for the extended running that CNC may involve. I have the paperwork that came with it and will check to see if anything is said about overheating. See also: https://www.model-engineer.co.uk/forums/postings.asp?th=142863 Edited By ega on 21/07/2019 17:30:19 |
Raymond Griffin | 22/07/2019 16:02:26 |
65 forum posts 48 photos | Hi Rob, I attach a copy of the lubrication advice for the Quick Step Mill. I only use mine in the horizontal mode, so cannot comment on vertical use. My motor does become a little warm with extended use. The gearbox runs cool, but I only run mine at slower speeds for milling/drilling work held in the chuck of the lathe. Could be worth ringing Kirk at Hemmingway. I believe that he has used a QSM extensively. I find the QSM an invaluable addition to my lathe. I purchased my unit new but found that I needed to top up the oil. |
ega | 22/07/2019 16:28:30 |
2805 forum posts 219 photos | I must check my oil level! I made a small mod to the belt cover on my unit which allows me to apply a gentle push to the machine when needed (I have to take care not to attempt to lift the machine by the new handle):
Phil Sanders | 13/04/2021 07:02:48 |
2 forum posts | Having recently inherited a quick step mill. Where actually is the oil level /plug situated? |
