Large Pulley wheels
Speedy Builder509/07/2019 19:58:05
2878 forum posts
248 photos
Perhaps an unlikely source of V belt pulleys is spare parts for ride on mowers - typically the drive pulley on the gear box / rear axle is about 225mm diameter.
BobH
not done it yet09/07/2019 20:25:29
7517 forum posts
20 photos
I see lots and lots and lots of belts at some auctions. Unfortunately, unless you know exactly what you are looking for and it is there, mostly a dead item to bid on.
Same goes for hydraulic pipes - buy a huge amount for peanuts and only use a couple - then have to offload them or dump the rest. Still a huge saving on the couple you can use, though!
Certainly found it better to buy the I need from a local stockist as they are not an expensive item - apart from timing belts
Ian S C10/07/2019 11:46:15
7468 forum posts
230 photos
Old washing machine/clothes dryers, a bit over 12"(I think) A section belt.
Ian S C
