Main spring
Smiths Mantle Clock
Speedy Builder507/07/2019 19:01:35
2878 forum posts
248 photos
I have been asked to look at a Smiths Manthe clock dated 1 sept 1950, just 4 years after I was born ! Both the main and chime springs were overwound, but there doesn't seem to be enough Zing in the main spring to make the escape wheel to turn. If I take the escapement off, the wheel turns OK. I have cleaned and sparsely oiled all the bearings, but still not enough to make the escapement tick back and forth even without a pendulum.
Has the Zing gone from my spring - and can I get it back ?
BobH
Michael Gilligan07/07/2019 21:11:22
23121 forum posts
1360 photos
More likely that the clock needs a good clean, and possibly some re-bushing.
Even a tired old spring should have the zing to move the thing
P.S. ... a few close-up photos might help with our attempts at remote diagnosis
Speedy Builder508/07/2019 11:24:29
2878 forum posts
248 photos
It all looks in a clean condition although the mainspring releases itself with a bit of a 'jump' every now and again. I assume this may be due to old oil causing the coils of the spring to 'glue' together, but before I take that out and clean it, I thought a few questions / thoughts may be in order.
Here are some photos, but don't know if they help. The clock is marked SMITHS Enfield and on one corner is marked HF. The wooden case is dated 1/9/1950
BobH
Edited By Speedy Builder5 on 08/07/2019 11:25:22
Martin Kyte08/07/2019 11:33:29
3445 forum posts
62 photos
Mainspring 'jumping' shows the spring is need of cleaning and relubricating. Do be carefull if you intend taking it out of the barrel although you should be able to do a reasonable wash out with solvent. Relubricate with a dribble of motor oil on the edge of the coil, it will work it's way in. You need to ensure that all the pivots are lubricated too with clock oil.
regards Martin
Bazyle08/07/2019 11:51:32
6956 forum posts
229 photos
They must have made millions of those movements - I've got a couple sans case and some other bits. Look out for worn pinions where you might need to move the corresponding wheel along a bit.
I've always wondered why the plates are covered in that pinhole pattern. Was it some technique of flattening the raw stock?
Michael Gilligan08/07/2019 12:16:42
23121 forum posts
1360 photos
Thanks for posting the photos, Bob
I see that Martin and Bazyle have already replied helpfully
From what I can see at that resolution, the movement looks relatively unworn
As for the pivots: They need to be very free-running, especially towards the escapement end of the train ... Tip the movement onto its back, and then over to its front; all the arbors should move freely and 'click' as they contact the plates.
You are probably right to suspect gumming-up of the mainspring.
A strip-down & clean would almost certainly be effective.
@ Bazyle ... Yes, the dimples are evidence of a flattening process.
KWIL08/07/2019 13:57:05
3681 forum posts
70 photos
Early TV and radio chassis were also similarly dimpled, not only flattens but more important, it stiffens the plate. They used very thin sheet steel in those days.
Speedy Builder508/07/2019 14:14:08
2878 forum posts
248 photos
I suppose its too late to go back now !!
Michael Gilligan08/07/2019 14:49:53
23121 forum posts
1360 photos
Well done, Bob
I suggest you watch this before re-assembling: **LINK**
https://youtu.be/ep4zBK2rmnk
[ sorry, couldn't find the embed link ]
Speedy Builder508/07/2019 15:43:49
2878 forum posts
248 photos
Thanks everyone, its been an interesting afternoon and have been talking to Meadows and Passmore. It is more than likely that the spring is weak and another is on order - Well, they do sell springs !
Watched the video thanks Michael and found this one too. **LINK**
I never realised just how clean bearing had to be, I suppose its the problem of working with an Austin 7 for the last 44 years!
BobH
