Small modeling lathe
Help
Rob Gourlay 107/07/2019 17:10:06
1 forum posts
Hi everyone just joined the site as I have a a small adept modelling lathe and was wondering what people would think about my chances of renevating it I would post a couple of picture but need help doing it sorry not very technical thanking in advance
Plasma07/07/2019 18:30:53
443 forum posts
Welcome Rob.
You've opened a can of worms asking about the Adept lathe lol.
Some love em, some loathe em, some refer to them as boat anchors.
I have two waiting to be renovated, not to use as I have much better machines in my main shop. But they look good in the house.
Regards mick
not done it yet07/07/2019 18:55:06
7517 forum posts
20 photos
Posted by Plasma on 07/07/2019 18:30:53:
Regards mick
To keep the doors open or closed?smiley Sorree, couldn’t resist.devil
Former Member07/07/2019 19:01:48
1329 forum posts
old mart07/07/2019 19:33:01
4655 forum posts
304 photos
Information on the Adept lathes can be found on the lathes UK site.
Frances IoM07/07/2019 20:08:12
1395 forum posts
30 photos
what do you plan on using it for ? Don't forget it was the lowest priced lathe of its period some 70+ years ago - repainted it will probably look good as an ornament but as a serious lathe no way.
Former Member07/07/2019 20:16:13
1329 forum posts
Frances IoM07/07/2019 21:18:48
1395 forum posts
30 photos
I don't have an adapt but I do have one of its competitors a flexispeed student - but I have a WM180, a Perris Me90 and also a Taig - the latter is probably the most usable cheap lathe I've seen, the Perris is the precursor to the now very expensive Cowells
Given sufficient time and some expertise the adapt can probably produce acceptable small scale work but it depends on what the OP envisages using it for.
James Alford07/07/2019 22:04:48
501 forum posts
88 photos
I know that everyone has their own thoughts, but having owned a Peatol (Taig) and now a Flexispeed, I have to confess that I find the Flexiespeed much better, more usable and easier to control than the Peatol. Admittedly, the Peatol was an earlier version, bought in the early 80s.
James.
Niels Abildgaard08/07/2019 07:51:22
470 forum posts
177 photos
Posted by Frances IoM on 07/07/2019 21:18:48:
How do You rate the WM180?
I am asking as I am trying to improve one with a much bigger spindle and VFD.
Am I wasting my very precious last years on a painted tart?wm 180 ER40nose
Frances IoM08/07/2019 08:13:04
1395 forum posts
30 photos
Niels: the WM180 is adequate for the tasks I use it for - I have a small cellar workshop so space and access somewhat restricted - the two annoyances I have are the awkward + restricted nature of gear changes if you want to screw cut and the lack of T-slots or room to put mounting holes on the cross slide.
As to your 'painted tart' - each to their own - some enjoy making tools other see this solely as a means to enable other tasks and somewhat begrudge the time spent
Former Member08/07/2019 08:38:46
1329 forum posts
Niels Abildgaard08/07/2019 08:47:50
470 forum posts
177 photos
Posted by Frances IoM on 08/07/2019 08:13:04:
Sounds interesting as my goal is to make the best performing lathe within the space cube of a WM180.
The changes are:
Solid base of Dolerite
Much stiffer spindle with less overhang
Stiffen up the headstock ,bed connection .Either Epoxycrete the bed or put a hefty brace of steel steel between Dolerite and headstock.
Your gearchange annoying will be avoided by having an electronic leadscrew .
The cross slide lack of stud holes are more difficult to remedy.
If and when I have it running,it will be tested like this:
Cutting M16 Unbrako 12.9 bolt
Do You know if there is a forum for WM180 lathes and will You be interested to try finding the limits of Your present WM180?
I can send some screws?I have a quarter bucket.
Bob Stevenson08/07/2019 09:35:52
579 forum posts
7 photos
I have been using a WM180 for about 18 months. It replaced a Chinese mini-lathe as my 'house lathe' and is a much better machine. I have discovered that at least two other members of Epping Forest Horology Club also have WM180's and it does indeed offer the basis for a very inexpensive and useful clock makers lathe at about one third the price of a clapped out Swiss Schaublin which has less facility. It's yet another case of "horses for courses". I have a Colchester Master but the WM180 is ideal for late night use in a corner of my conservatory and raises no objections from the management!
To Niels question of whether he is wasting his time trying to improve his 180 I woud say that he is because when he 'falls off the perch' it will go straight in the skip as a piece of ruined junk. The WM180 is what it is,...either get busy maing stuff or get another, better, bigger lathe.
For me the WM180 would take a lot of beating...in fact there is no equal in it's class for what I require,..it comes with a couple of nice chucks, is resonably well designed (much better than mini-lathe) and performs well inside it's capability. The only issue for me is that I require some specific clock making kit which has to be made up, but I have just cut a clock fusee by turning the chuck by hand with cross slide screw removed and I delighted with how it went as it could not have been simpler and would have been impossible on a Swiss lathe without VERY expensive accessories
Lainchy08/07/2019 09:37:33
273 forum posts
103 photos
I'd be interested if there was a WM180 forum... I have the Chester DB7 which is essentially the same lathe.
Former Member08/07/2019 09:50:19
1329 forum posts
Frances IoM08/07/2019 10:02:48
1395 forum posts
30 photos
Bob: I don't think Niels is wasting his time if the aim is to demonstrate that a more capable lathe could be built within the confines of a WM180 foot print - whether such a creation could ever be taken up and produced for the low price of the WM180 is extremely doubtful but the discussion of small changes etc to improve certain aspects would be useful.
However there are several existing web blogs some dating back 10 years or so on various mods to improve the WM180 - maybe these could be collated and the info archived before the usual web-rot sets in as sites disappear or photos hosted on 'free' sites are deleted as sites become no longer free.
Bob Stevenson08/07/2019 10:21:29
579 forum posts
7 photos
This bloke who does 'Ade's Workshop' on yutube uses a WM180 and has made a few improvements including his current project od electronic feed motor;
https://www.youtube.com/watch?v=tG5fES1vGnY
The lack of cross slide slots was teh one thing that made me pause for thought before aquiring the 180 and I will admit that i considered an old myford,...however, I wanted to make clocks not refurbish clapped out lathes.
Neil Wyatt08/07/2019 14:34:41
19226 forum posts
749 photos
86 articles
Adept lathes are very old fashioned and very basic, especially if it's the fixed-slide Adept rather than the Super Adept.
If you have one with little wear and well set up, it will happily work metal within its capacity but it will always be harder work than using a more modern machine.
My own adept, much modified and still waiting for me to finish the tumbler reverse, add a screwcutting clutch and put it on a base board...
Edited By Neil Wyatt on 08/07/2019 14:36:04
