Advice needed about 1940's lathe
Jet Payne | 11/06/2019 10:45:47 |
2 forum posts 4 photos | Hello, I recently inherited a working 1940's metal work lathe, it's a Le Blond, 'Regal 10' lathe, circa 1942 (American made). I've been told it's quite rare? Does anyone know anything about these lathes? Unfortunately I must move or sell the lathe asap as it can't stay in its current location in Essex, but I'm at a loss about how to do this or where to go to :
There is also a Progress '2G' Bench Drill circa 1946:
And an Adcock & Shipley Horizontal Milling Machine circa 1940's:
Any advice that anyone can offer on any of these would be really helpful.
Thanks
Jet Edited By Neil Wyatt on 11/06/2019 18:31:42 |
Brian Wood | 11/06/2019 12:48:47 |
2742 forum posts 39 photos | Hello Jet, Try Steve Cox of Landylift , based in West Yorkshire. They are frequently recommended on this forum although I have no direct experience so I can only pass on the views of others who have used him Phone 07836 736496 email [email protected] Regards Brian |
ega | 11/06/2019 14:59:42 |
2805 forum posts 219 photos | Might someone rotate these interesting photos so that they can be viewed in comfort, please? |
V8Eng | 11/06/2019 15:37:48 |
1826 forum posts 1 photos | I could but it might infringe Jet’s copyright. Edited By V8Eng on 11/06/2019 15:44:16 Edited By V8Eng on 11/06/2019 15:44:42 |
Jet Payne | 11/06/2019 17:49:47 |
2 forum posts 4 photos | Hello,.... feel free to rotate the pictures..... I can't seem to do it...... thanks |
Daniel | 11/06/2019 18:16:42 |
![]() 338 forum posts 48 photos |
ega | 11/06/2019 18:35:27 |
2805 forum posts 219 photos | Daniel Thank you. A favourite jingle comes to mind: Dare to be a Daniel, No doubt we shall be prosecuted together for copyright infringement! Nice lathe, by the way. |
Daniel | 11/06/2019 18:47:20 |
![]() 338 forum posts 48 photos | Posted by ega on 11/06/2019 18:35:27:
Pete Rimmer | 11/06/2019 19:24:35 |
1486 forum posts 105 photos | Interesting chuck on that LeBlond. Seems to be a 3-jaw with both independent and scroll adjustment. |
Bazyle | 11/06/2019 20:33:14 |
![]() 6956 forum posts 229 photos | The lathe is similar in size to a Boxford so only 3-400lb and quite easy to lift or move around with an engine crane or block and tackle if the garage beams are suitable and loaded into a small trailer or back of a transit. I would take it off the legs though. If you stripped it further you could manhandle it into an estate. Hope you keep the machines and decide to take up model engineering. |
Howard Lewis | 11/06/2019 20:47:08 |
7227 forum posts 21 photos | They all look likew useful bits of kit As I understand it, Le Blond was a good quality machine. Hopefully, you can find someone near you, with a crane to move the machines.. FWIW, when lifting the machines, sling bthe drill from the head, using the table and lower column to keep the C of G low down. Ditto for the Mill, if possible. For the lathe, hopefully there will be a sling long enough to pass under the Headstock and Tailstock ends, making sure that the sling cannot slip Keep it clear of the Leadscrew and power shaft, so that they do not get bent! If you have to sling around the bed, the Tailstock, Steady and Apron are use ways to adjust bhe C of G to balance the lathe and keep it level. Beware of trying to lift and move unwieldy and weighty machines, by hand.. They are liable to fall over and damage themselves and you part way through the process; usually when negotiating a doorway or steps. Good luck! You have basis of a good workshop there. Do find a M E Club and join. Howard. |
