Apparently a Diesel pressure tool...?
Simon0362 | 10/06/2019 16:36:05 |
279 forum posts 91 photos |
I have had this tool for some time on the basis that "it will come in useful sometime..." I have now arrived at the point where its time to move this onto someone who a) knows exactly what it is and b) can use it... I have advertised it on Homeworkshop in the hopes that someone would see it and decide they knew what it was but no takers. If anyone can tell me what it is - or even take it off my hands I would be very happy. I believe it is a pressure sensor for fluids where the lamp under the red cover lights up at pressure "X", whatever that might be. Beautifully made and heavily chromed and looks almost unused - but maybe unused for a good reason! BR |
Journeyman | 10/06/2019 16:46:13 |
![]() 1257 forum posts 264 photos | Wilmonda seem to make specialist tools for the motor trade ( see ***HERE*** ). No idea what this one is for though? John Edited By Journeyman on 10/06/2019 16:47:49 |
not done it yet | 10/06/2019 18:28:49 |
7517 forum posts 20 photos | Several pics/vids on the net if you search on ‘goggle’. Must be some information there. |
Former Member | 10/06/2019 18:42:38 |
1329 forum posts | [This posting has been removed] |
Mike Poole | 10/06/2019 19:36:18 |
![]() 3676 forum posts 82 photos | The one on eBay seems to be on the same table as Simons. Mike |
Speedy Builder5 | 10/06/2019 19:39:52 |
2878 forum posts 248 photos | Hello, it is a diesel injection pump timing tool (drop timing!) on "in-line" pumps the banana plug connects to the end of the tool, the crocodile clip on a +bat. and the conical connector on an outlet of the pump it is not "specific to PL
Ps, translation from the French Panhard club forum |
Speedy Builder5 | 10/06/2019 19:45:02 |
2878 forum posts 248 photos | More info |
Simon0362 | 10/06/2019 20:03:01 |
279 forum posts 91 photos | Posted by 34046 on 10/06/2019 18:42:38:
It’s an oil and fuel pressure tester. There is one on EBay for £25 Bill Edited By 34046 on 10/06/2019 18:43:25 Yes, its mine..... |
Simon0362 | 10/06/2019 20:04:44 |
279 forum posts 91 photos | Posted by Speedy Builder5 on 10/06/2019 19:39:52:
Thanks, I found some things from the Panhard club too - but nothing suggesting it was either specific to something nor the 'proper' application fr it |
Simon0362 | 10/06/2019 20:06:06 |
279 forum posts 91 photos | Posted by Speedy Builder5 on 10/06/2019 19:45:02:
More info Sadly, all I get is a nice link to mine..... |
Former Member | 10/06/2019 20:18:22 |
Former Member | 10/06/2019 20:18:31 |
[This posting has been removed] | |
old mart | 11/06/2019 18:54:32 |
4655 forum posts 304 photos | Yes, Haggerleases, now you bring the title to my attention. I have all the programs on dvd. |
Howard Lewis | 11/06/2019 21:12:03 |
7227 forum posts 21 photos | The nipple is obviously one meant to connect to an Injection pipe connection. Most likely to be used as a timing tool connected to the High Pressure outlet of (usually ) No 1. As said, as the engine is rotated, the pressure build up will light the light, to indicate the start of injection. A cleaner way than spill timing. an In Line, but could also be used on a rotary such as the Roosa Master, CAV DPA,, DPS, Bosch EPVA, EPVE, or any of the Stanadyne pumps. It looks unused, but the size of the nut makes it look like it is meant for 'A' size connections, so probably not for anything bigger than a pump with a 10mm plunger size, so relatively low powered engines, (Not much more than 30-40 bhp / cylinder even if turbocharged. ). Howard |
Simon0362 | 12/06/2019 23:18:19 |
279 forum posts 91 photos | Thanks for all of the input, especially Howard’s detailed description. It came from one of our local ‘vide grenier’ car boot sales in southern France so that may also tie in with the low power comments reflecting the popularity of diesel engines here for all forms of transport until recently. I thought that it was unused until I took the photos and then saw some graunch marks on the knurled knob where someone has gently taken a pair of pliers or the like to it. Not serious but not perfect... Maybe a tool to pass to my neighbour who has a fine collection of French classics Simon
