Acetal Faced Machinist Hammer
Blue Heeler02/06/2019 03:16:02
342 forum posts
G'day all,
What's the best method of attaching black acetal to a machinist hammer(s) that I'd like to make.
Thinking of making two, one the middle part brass faced with two acetal ends and one aluminium with two acetal ends.
Boiler Bri02/06/2019 05:25:09
856 forum posts
212 photos
Hello. I would not use acetol for a hammer face as it chips and fractures easily. Try HDPE as its more flexible and less likely to chip off.
My soft face hammers are threaded to hold the replaceable faces.
Bri
Blue Heeler02/06/2019 05:32:59
342 forum posts
Thanks for the heads up in regards to HDPE.
Cheers
Jim
P.S just looked up the eBay listing in my purchase history, I bought this as a batch of offcuts in 2017 and it is listed as HDPE
Edited By Blue Heeler on 02/06/2019 05:35:25
Edited By Blue Heeler on 02/06/2019 05:35:47
old mart03/06/2019 09:49:44
4655 forum posts
304 photos
Nylon is commonly used for heads.
Ian Johnson 104/06/2019 17:26:18
381 forum posts
102 photos
Yes HDPE is good for a hammer head, years ago I made a small machinists hammer with a brass head and the other head was made from PTFE (Teflon) both held in by two small grub screws, occasionally need tightening up but works very well, the PTFE is especially good at not marking delicate components.
Ian
Mike Poole04/06/2019 17:31:22
3676 forum posts
82 photos
I think hide and copper take a lot of beating for soft faces, no pun intended.
Bazyle04/06/2019 18:40:41
6956 forum posts
229 photos
Posted by old mart on 03/06/2019 09:49:44:
I find wood the most common - Oh you're still talking about hammers. smiley
Dalboy04/06/2019 18:46:47
1009 forum posts
305 photos
HDPE can be found everywhere about you and can be molded to shape, just don't use the house oven to do it. Woodworkers have made carving mallets from plastic milk bottle tops and even pens which can be turned
Edited By Derek Lane 2 on 04/06/2019 18:48:16
Hopper05/06/2019 08:06:37
7881 forum posts
397 photos
The usual method of attachment is to make the body (usually steel) with a female thread tapped into each side, about half the diameter of the head. The plastic face then is machined up with suitable step and the smaller diameter either screwcut or die-threaded to screw into the body. Coarse thread such as BSW or metric coarse series works best on the plastics. Be sure the threaded part is short enough that the plastic face part seats on the back of the face with no gap.
