Roger Hulett | 27/05/2019 16:41:45 |
131 forum posts 9 photos | I am beginning to assemble my brass,home made carburettor. I have faithfully copied the original. It is necessary to solder the parts together. However, some parts have to be soldered to other parts that have already been soldered. Is there a technique for keeping the old parts cool whilst heating up adjacent parts for soldering. The parts can not be soldered simultaneously. |
Ian P | 27/05/2019 17:05:34 |
![]() 2747 forum posts 123 photos | Usual method is to use two or more solders with different melting temperatures, (use the higher temp one first) Ian P |
Jeff Dayman | 27/05/2019 17:16:43 |
2356 forum posts 47 photos | You can use the old trick of wrapping the end you want to keep cool in a wet rag, or embed it in a cold raw potato. Sometimes just clamping on a hemostat or attaching a piece of copper sheet with an alligator clip will do. Good luck! Edited By Jeff Dayman on 27/05/2019 17:17:38 |
Roger Hulett | 30/05/2019 15:46:12 |
131 forum posts 9 photos | Further to this topic, adjacent to the item being soldered there is a threaded section. Obviously I don't want to let the solder run into this area. Is there an anti flux,something that prevents the solder running into the threads..... Vaseline,grinding paste,butter, 3 in i oil ? |
Former Member | 30/05/2019 16:07:06 |
1329 forum posts | [This posting has been removed] |
BC Prof | 30/05/2019 16:25:57 |
182 forum posts 1 photos | If its silver solder I use either "lead" from a pencil of Tippex correction fluid . Never tried it for soft solder Brian C |
John Billard 1 | 30/05/2019 18:01:53 |
111 forum posts | Tippex works for soft solder. John B |
