Grant Allen 1 | 13/05/2019 17:04:09 |
48 forum posts 5 photos | Has anyone had any problems fitting a modern tool post to the slide carriage, any issues you've come across and if alls working fine which brand and type did you use? I would just like to say all the help I've received on has been 1st class and has helped me and hopefully other people starting out in this field. |
David George 1 | 13/05/2019 18:03:20 |
![]() 2110 forum posts 565 photos | Hi I have fitted a Dickens type bought from Myford. Here is picture and sketch of my mod. David
Grant Allen 1 | 13/05/2019 18:11:11 |
48 forum posts 5 photos | Brilliant cheers David. Did you have and issues, obviously I dont have a lathe to do out on till this is done. Its abit like the lead screw half nut cant make one the lathe and cant make one with out a lathe.
ian j | 13/05/2019 18:24:24 |
![]() 337 forum posts 371 photos | I've used for several years a Bison (Tool mex) Type 4414 48 x 37 some times named T001 or S001 with a suffix of M or not.. They are a direct fit on the top slide of ML7's and Super 7's.They are expensive but top quality.
Edited By ian j on 13/05/2019 18:24:58 Edited By ian j on 13/05/2019 18:26:39 |
