Adam Harris | 07/05/2019 19:28:31 |
533 forum posts 26 photos | I understand how to determine the pitch of a gear by measuring the outside diameter and number of teeth, but how do I measure a rack to get the dimensions/pitch/other of a correctly meshing gear? |
JasonB | 07/05/2019 19:40:31 |
![]() 25215 forum posts 3105 photos 1 articles | For metric MOD pitches measure the pitch of the rack and divide by Pi (3.142....) For DP divide Pi by the pitch in inches. Best to measure the rack over say 10 teeth and then take the average rather than trying to measure just one tooth Edited By JasonB on 07/05/2019 19:50:02 |
Bill Davies 2 | 07/05/2019 19:44:54 |
357 forum posts 13 photos | Adam, if you have some dowels or pins of a suitable and identical size to sit about halfway down in the tooth space, you can measure over the pins, over a distance of several teeth. Subtract the diameter of one pin, and divide by the number of teeth, less one (i.e., counting from zero). By converting into appropriate units you can look up the pitch on a table of metric Module sizes, or diametral pitch (DP) for inch sizes. Hopefully, this should get you started: https://khkgears.net/new/gear_knowledge/abcs_of_gears-b/basic_gear_terminology_calculation.html Bill |
Bill Davies 2 | 07/05/2019 19:46:40 |
357 forum posts 13 photos | oops: |
Pete Rimmer | 07/05/2019 20:52:17 |
1486 forum posts 105 photos | Set your digital caliper to 3.142 inches and offer it up to the rack teeth. If the jaws span a number of teeth exactly then count the teeth they span - that's the equivalent DP of the rack. If the jaws don't span whole numbers of teeth then it's a module rack. Measure across ten teeth and divide the answer by 31.42. |
Adam Harris | 07/05/2019 21:01:31 |
533 forum posts 26 photos | Pete, that is without doubt the most excellent response anyone could hope for! Many thanks, Adam |
Michael Gilligan | 07/05/2019 21:23:15 |
![]() 23121 forum posts 1360 photos | Posted by Pete Rimmer on 07/05/2019 20:52:17:
[...] If the jaws don't span whole numbers of teeth then it's a module rack. . Or perhaps, a 'circular pitch' Imperial rack ? MichaelG. |
Pete Rimmer | 07/05/2019 21:40:45 |
1486 forum posts 105 photos | Yeah it could be that Michael, good call. |
Adam Harris | 07/05/2019 21:42:00 |
533 forum posts 26 photos | It is a metric machine (Schaublin 12) so indeed probably MOD |
Adam Harris | 07/05/2019 21:48:57 |
533 forum posts 26 photos | |
Michael Gilligan | 07/05/2019 21:59:18 |
![]() 23121 forum posts 1360 photos | Adam, That looks like an ideal application for a circular pitch rack [be it Imperial of Metric] ... measure carefully MichaelG. . Edit: The first two PDFs from this page should help http://www.davall.co.uk/dsg-power-transmission/catalogue/gears/ Edited By Michael Gilligan on 07/05/2019 22:02:39 |
Adam Harris | 07/05/2019 22:11:34 |
533 forum posts 26 photos | I will revert tomorrow in the daylight with measurements |
Adam Harris | 07/05/2019 22:12:33 |
533 forum posts 26 photos | Michael thanks for that link |
