Imperial Tube
6.25" o.d. x 6.00" i.d.
Chinkoa21/04/2019 19:53:28
40 forum posts
9 photos
Any ideas for a supplier. Need for a Smokebox.
Jeff Dayman21/04/2019 20:09:58
2356 forum posts
47 photos
ID? OD? Length? material? some hints would help. Also what country / region are you in?
JasonB21/04/2019 20:12:52
There is a clue under the thread title.
As you look to be building a loco from MJ Eng drawings have you asked Alan if he does a rolled and welded smokebox, got the one for my traction engine from him. He does seem to list one here if it is for that loco.
Edited By JasonB on 21/04/2019 20:17:37
Paul Kemp21/04/2019 20:17:26
798 forum posts
27 photos
Er...... I think the clue is in the title?! 6 1/2" OD by 6.00 ID (I think with my limited maths that's about 1/8" wall thickness) and given its a smokebox probably 4 - 5" long, it's not going to be that long anyway. I would assume the exact material is immaterial but non ferrous probably best for a corrosion point of view. If you got a piece of 1/8" copper plate it shouldn't be too hard to roll it round a former if it's well annealed. Sorry don't have any suggestions for a piece of tube though.
Oops Jason beat me too it!  If it's a traction engine then agree with Jason, steel would be best, more possibilities for supply too, I got a piece of 13" OD pipeline tube for mine and turned it down to 12 5/8".
Paul.
Edited By Paul Kemp on 21/04/2019 20:22:01
Chinkoa21/04/2019 20:25:38
40 forum posts
9 photos
Hi Jason,
Yes MJ. list one but they can no longer supply?
Paul,
Yes it's supposed to be 10G. The Smokebox is 10.3/16" long.
I have a 6.25 OD. Copper tube but it has a few dints in it that I mighthave to work around if I cannot find an Imperal tube supplier. My friendly neighberhood fabricating shop has rolls but cannot get down to 6" ID.
Colin
Chinkoa21/04/2019 20:27:03
40 forum posts
9 photos
It's for a 5" Gauge Merchant Navy Class
Colin
JasonB21/04/2019 20:39:29
Colin, if you are in MJ's part of the world try these people who do some good rolling work and will weld the ring too. They would roll it out of 3mm material.
Failing that M-Machine do 165mm OD thick wall steel seamless that could be turned down.
Chinkoa21/04/2019 22:56:28
40 forum posts
9 photos
Thanks for that Jason.
i am not in MJs area but iwill try them. My lathe won't entertain 165mm, I can get it in but I cannot turn as the saddle won't pass underneath the Tube.
Colin
Jeff Dayman22/04/2019 04:38:19
2356 forum posts
47 photos
JB and Paul - no idea what clue you mean. All I see under title is "All topics / Latest posts"
I see OP responded with OD and ID and length after your posts. I take it he's in UK somewhere.
Michael Gilligan22/04/2019 06:23:59
23121 forum posts
1360 photos
Posted by Jeff Dayman on 22/04/2019 04:38:19:
Jeff,
Scroll up to the title of this thread
... immediately below that is the subtitle.
Imperial Tube
Edited By Michael Gilligan on 22/04/2019 06:27:17
Chinkoa22/04/2019 06:54:03
40 forum posts
9 photos
Hi Jeff,
West Yorkshire
Colin
JasonB22/04/2019 06:55:04
It also shows up in the topic listings under the thread title.
Simon Collier22/04/2019 07:52:02
525 forum posts
65 photos
Simon Collier22/04/2019 07:56:14
525 forum posts
65 photos
8" 4 jaw holding 3/8 thick tube. Smokebox for Doncaster A3, 6-1/2" O.D. I think. Cross slide just cleared underneath by very little. Boring from the first end was OK, but it really started to ring and chatter when boring from the second end.bore.jpg
ega22/04/2019 10:24:13
2805 forum posts
219 photos
Jeff Dayman:
That problem with the title *might* be caused by an adblocker (if you are using one).
