Possible use of Gas Bottle
Speedy Builder5 | 10/03/2019 12:21:33 |
2878 forum posts 248 photos | just a thought, and welcome views of others. I use disposable CO2 mix gas bottles, 300 mm high 100mm diameter and wall thickness of 3mm. These have a working pressure of 100 bar at 20 deg C and test pressure of 145 bar. Made of steel and about 2.5 litre capacity. Could these be used for a vertical boiler, drilling the end caps for fire tubes etc etc.?
Ps Usual excuse for horizontal picture (Horizontal boiler ??). |
JasonB | 10/03/2019 13:09:50 |
![]() 25215 forum posts 3105 photos 1 articles | You can do what you like with them in your own shed but would not be able to run in public and if anyone did get hurt in private the ambulance chasers will also be after you for a bob or two. Having said that I have seen a couple of boilers complete with small engine made from these and they looked very good, will see if I can find the video. J |
vintage engineer | 10/03/2019 16:23:27 |
![]() 293 forum posts 1 photos | It depends what temperature you will running at. There must be a formula for calculating heat versus strength of steel. The higher the temperature the weaker the steel becomes. The comes a point where you get a sudden catastrophic failure, that's why steel beams in buildings have to be incased in plasterboard.
Paul Kemp | 10/03/2019 16:40:25 |
798 forum posts 27 photos | Posted by vintage engineer on 10/03/2019 16:23:27:
What sort of temperature would you envisage running a vessel that boils water at? Are you talking flash steam generators here? Considering iron derivatives have been used for boilers since the industrial revolution and most full size boilers are steel, running at far higher loadings than proposed here I hardly think the material properties of the gas bottle will be a problem. It may be commercially un certifiable for other reasons such as traceability but as a small boiler operating at up to say 80psi temperature isn't going to be a factor. Paul. |
JasonB | 10/03/2019 16:51:20 |
![]() 25215 forum posts 3105 photos 1 articles | Here you go, couple of really nice engine/boiler combinations. Jump to a bout 2mins in to see one under steam. |
SillyOldDuffer | 10/03/2019 17:31:50 |
10668 forum posts 2415 photos | Using something outside normal design parameters is an 'unbounded risk', that is there are too many unknowns to allow a prediction to be made. The absence of data makes repurposing the cylinder as a boiler component a bit dodgy. On the plus side the cylinders are professionally made of steel and pressure rated at 20C to 100 bar (about 1400psi). That's substantially stronger than a typical small copper boiler. On the negative side, we don't know how good the steel is at resisting hot wet corrosion, or if the construction is in any way vulnerable to heat. Also, the pressure rating is for a disposable item, ie. a gas cylinder not designed to withstand more than one cold pressure cycle in it's entire working life. As such the build is likely less strong than would be used for a hot boiler cycled several hundred times. Although uninsurable my feeling is that the pluses outweigh the negatives as a way of occasionally making low pressure steam in a private workshop. Up to, say, 60psi with suitable precautions like a shield. As the cylinders are cheap the risk could be reduced by changing the boiler shell before fatigue or corrosion have had time to cause damage. It would be interesting to comprehensively test a boiler made from a gas cylinder over a few months and then take it apart. If all was well inside, confidence would rise. Or the opposite! Dave
Edited By SillyOldDuffer on 10/03/2019 17:32:13 |
Brian Rutherford | 11/03/2019 17:17:14 |
109 forum posts 3 photos | I was thinking of using then filled with compressed air for running simple steam engines with a suitable regulator fitted. Filling from a compressor to about 100 bar |
Brian Rutherford | 11/03/2019 22:18:37 |
109 forum posts 3 photos | Posted by Brian Rutherford on 11/03/2019 17:17:14:
I was thinking of using then filled with compressed air for running simple steam engines with a suitable regulator fitted. Filling from a compressor to about 100 bar Sorry should have said 100 psi Edited By Brian Rutherford on 11/03/2019 22:19:16 |
