Dave T | 02/02/2019 11:45:18 |
69 forum posts 1 photos | Hi All, A couple of days ago I was reading a post regarding ER32 chucks and there was a drawing produced by John Stevenson in the thread - I could have sworn I bookmarked it, but now I can't find it! Can someone please point me in the right direction? Cheers Dave |
not done it yet | 02/02/2019 12:37:16 |
7517 forum posts 20 photos | Does your computer store all(?) the internet pages recently visited? Mine does and likely has hundreds of pages in its memory. My previous tablet only saved pages for a few days. |
David Standing 1 | 02/02/2019 13:14:04 |
1297 forum posts 50 photos | The one in this thread? |
Michael Gilligan | 02/02/2019 13:18:55 |
![]() 23121 forum posts 1360 photos | You might start browsing here, Dave : **LINK** https://www.google.com/search?q=er32+chuck+stevenson+site%3Amodel-engineer.co.uk&tbm=isch&ved=2ahUKEwjno-m4kJ3gAhWm0eAKHTY9DtwQ2-cCegQIABAC&oq=er32+chuck+stevenson+site%3Amodel-engineer.co.uk ... see if you recognise any of the pictures. MichaelG. . Edit: David might have got there first. Edited By Michael Gilligan on 02/02/2019 13:20:07 |
Howard Lewis | 02/02/2019 13:20:49 |
7227 forum posts 21 photos | Yes, make thethread and register for the Mandrel, and then turn the tapers and thread, in situ, to maximise concentricity. The Internal taper is 16 degrees (8 degree offset for the Top Slide ). I finish mine by CAREFULLY lapping with some emery and oil, wrapped around a collet. DON'T push too hard or it will grab!!!!!!!!!! The thread for ER32 is 40mm x 1.5mm pitch. Howard |
Lambton | 02/02/2019 13:46:00 |
![]() 694 forum posts 2 photos | When testing your machined 16degree total taper always mount you test collet on piece of close fitting ground steel bar. If you don't do this the collet will flex and take give "satisfactory" result even if the taper you have bored is inaccurate. Eric |
ega | 02/02/2019 14:00:23 |
2805 forum posts 219 photos | I haven't seen the JS design but when I made my ER chucks I designed them to be rather longer than necessary so that the tool could get right up to the chuck without the saddle oversailing into the gap of the bed. My tapers were turned with the topslide set via the Smith gauge whose details I previously posted. |
Dave T | 02/02/2019 17:39:43 |
69 forum posts 1 photos | Posted by David Standing 1 on 02/02/2019 13:14:04:
The one in this thread? That's the one - didn't realise it was for an ML7 Many thanks David |
Chris Trice | 02/02/2019 17:44:09 |
![]() 1376 forum posts 10 photos | The only thing that makes it for an ML7 (or Super 7 or ML10) is the screw on Myford nose aspect. The ER part remains the same. |
Dave T | 02/02/2019 20:10:37 |
69 forum posts 1 photos | Yes, but I was searching for Super 7 today |
