superheaters
General questions
Peter Russell 429/01/2019 17:27:59
72 forum posts
Hi can any one advise on which material to use for a super heater in a model locomotive.
I guess it should be stainless - but which one 304 316 etc
What wall thickness based on 3mm od
How to bend it.
Assuming it will be a single piece bent the joints will be in the smoke box so could they be high temp silver soldered.
Its going in a single flue tube gas fired boiler
Any other advice please
Thor 🇳🇴29/01/2019 17:54:32
1766 forum posts
46 photos
Hi Peter,
The subject has been discussed before, here are a few links:
***Link***
***Link***
***Link***
Thor
duncan webster29/01/2019 19:35:54
5307 forum posts
83 photos
Do you really mean 3mm OD? That is going to be very small ID. As for material, use what you can get, I doubt you'll have much choice
JasonB29/01/2019 19:38:22
Could you get much larger into a G1 loco?
Simon Collier30/01/2019 02:31:14
525 forum posts
65 photos
This is a superheater for my G1 Eric made from a bit of 4 mm tube scrounged from a dead coffee machine. Stainless but no idea what grade, but good enough for the temperatures and pressures of an espresso machine. The inside radius is about 7/8". When I bend small tube I make a groove as wide as the diameter- a close fit- in a bit of bar with a parting tool, as deep as the diameter. I anneal the tube and bend. It can't flatten as it is constrained by the groove walls. Roundhouse use 1/8" stainless superheaters in their locos and kits.
