Mike Waldron | 05/01/2019 08:22:24 |
51 forum posts |
Good morning all: I am a member of both the Drummond and Myford Yahoo groups, so anyone else who is will probably be already acquainted with this topic. I am currently considering upgrading my Drummond M spindle from the lean 1MT provision to ML7 thread + 2MT socket. Has anyone else done this? I would be interested to hear of your exploits. Also - in and around November 1960 to January 1961, a certain Mr Jennings rote a 5 part article about his upgrade of a Drummond Admiralty model, using his other one! I guess he is no longer with us, but did anyone know him? Mike
Michael Gilligan | 05/01/2019 08:44:54 |
![]() 23121 forum posts 1360 photos | Mike It wasn't a Drummond, but that's probably of no importance Way back ... I did something similar: I made a screw-on boss for the existing nose and fixed that in place; then [in situ] turned a vee groove at the joint line. ... Then dismantled the lathe and took the spindle to be mig-welded ... reassembled the lathe and finished the machining of the new nose. Stepping things forward just a little did help make room for the 2MT socket without weakening the spindly spindle. MichaelG.
Mike Waldron | 05/01/2019 09:07:25 |
51 forum posts | Michael: My thought is not to go the whole hog and enlarge the spindle, bearings and bored as Mr Jennings did, but merely to make a larger nose register and thread. A slight enlargement of the front journal can be accommodated - just - apparently, so that’s my course of action once the weather gets a bit warmer. Mike |
Ady1 | 05/01/2019 09:35:13 |
![]() 6137 forum posts 893 photos | It's a huge job and an interesting project but considering the amount of work involved I would just go out and buy a Boxford The spindle is the "easy bit" Absolutely everything has to be upscaled to back it up, a new pulley would need to be cast etc A 1 inch bore would need what? a 2 inch spindle? Myford have a big bore so that could give you the basic dimensions Probably easier to adapt and bolt an atlas 10 inch headstock to a drummond bed But even the mighty atlas 10 inch only has a 25/32" bore |
Michael Gilligan | 05/01/2019 09:48:54 |
![]() 23121 forum posts 1360 photos | Posted by Mike Waldron on 05/01/2019 09:07:25:
Michael: My thought is ... merely to make a larger nose register and thread. . Which is what I did ['though the exact details are a fading memory] I just shifted the register face a little [towards the tailstock] to avoid weakening the spindle by enlarging its MT size. May I suggest that you first draw a sectional view of the current arrangement, and overlay 2MT, to identify any potential weakening. MichaelG.
Ady1 | 05/01/2019 10:09:12 |
![]() 6137 forum posts 893 photos | You could probably squeeze a 2MT into the existing spindle Then use an adaptor for fitting Myford bits |
Bazyle | 05/01/2019 11:01:10 |
![]() 6956 forum posts 229 photos | There is a pdf drawing on the Yahoo Drummond files section for an M spindle. Scaling that on my screen to be lifesize I held a M2 taper over it and there is room for 3 inches of depth so may need to look at the thin end.
