Colin Heseltine | 24/11/2018 20:39:05 |
744 forum posts 375 photos | Using my Chester Super Lux mill today for a couple of house. Working quite happily no issues at all. Stopped whilst checked a couple of dimensions, hit start and all I got was a humming noise. Nothing tripped out, no smells smoke or anything like that. Although had machine for around possible ten years I guess it has not done more than 20 or 30 hours work in that time. Any one any idea as to what might have failed. Colin
shaun hill | 24/11/2018 20:45:33 |
18 forum posts | I had a similar problem on mine, turned out the start capacitor had packed up, put a new one on, went for years more |
Neil Wyatt | 24/11/2018 21:11:16 |
![]() 19226 forum posts 749 photos 86 articles | My bandsaw had the same symptoms,m except I coudl start it by pulling on a belt. Once again a new start capacitor fixed it. Use the same of close capacitance value and make sure you have the same voltage rating as the old one. Neil |
Colin Heseltine | 25/11/2018 11:51:16 |
744 forum posts 375 photos | I tried the mill this morning and on second attempt it started. The capacitor is a CD60 250volt, 150 microfarad.. Other than Hong Kong does anyone have any suggestions as to where to find similar sized capacitor. Thanks, Colin |
Les Jones 1 | 25/11/2018 12:15:14 |
2292 forum posts 159 photos | This is one possible source
Before buying a new capacitor check that the centrifugal switch is closed when the motor is stopped. If you don't know how to do this you will need to post a picture of the connection box on your motor. Les, Edited By Les Jones 1 on 25/11/2018 12:17:58 Edited By Les Jones 1 on 25/11/2018 12:18:53 Edited By Les Jones 1 on 25/11/2018 12:20:14 Edited By Les Jones 1 on 25/11/2018 12:20:50 |
Neil Wyatt | 25/11/2018 12:31:22 |
![]() 19226 forum posts 749 photos 86 articles | I'd be tempted to upgrade to a 450V capacitor for long life. Neil |
Martin Connelly | 25/11/2018 13:12:41 |
![]() 2549 forum posts 235 photos | As Neil says don't get a 250V capacitor. Mains voltage of 230V rms has a peak voltage of 325V. Unless you know for certain that the 250V is an rms value you run the risk of rapid failure again. Martin C |
Les Jones 1 | 25/11/2018 14:31:15 |
2292 forum posts 159 photos | I agree that it worth getting a 450 volt rated capacitor if you can. Les. |
Colin Heseltine | 25/11/2018 18:15:53 |
744 forum posts 375 photos | I know that my mains voltage tends to be high. I have a UPS that regularly held the voltage down as it was experiencing voltages greater than 250v. I have put pictures of the existing capacitor and motor junction box in my album, For some reason they will not add to this post. Les, I do not know how to check centrifugal switch. Picture of junction box is in my album Colin |
Jon | 25/11/2018 19:44:46 |
1001 forum posts 49 photos | Two caps on mine. For what its worth mine has been used daily since 2004 to 2010 approx 2hrs a day, 2010 onwards approx 5 hrs a day. Only in peak times the supply voltage drops to around 253v, often 260v+ Wish it been the motor that packed up on mine, but just about everything else. Motor would have changed for a faster jobby, fastest speed is just too slow at 1250 rpm making that 1hr job take 2hrs or more.
Les Jones 1 | 25/11/2018 20:01:49 |
2292 forum posts 159 photos | Hi Colin, Les. |
Colin Heseltine | 09/12/2018 17:51:07 |
Took left hand capacitor lead off junction box and put meter across capacitor connections on junction box (no reading), tried across capacitor leads no reading. Meter set to 20 ohms scale, displays a 1 when nothing connected sand still displays a 1 when connected across the junction box or the capacitor. Loathe to try live electrical test as no one else at home at present. Pictures of junction box, electrical circuit and motor plate below.
Colin |
Dave Halford | 09/12/2018 18:14:56 |
2536 forum posts 24 photos | It's hard to test a cap with a digital meter, the discharge kick is often too fast to operate the display. |
Les Jones 1 | 09/12/2018 19:07:05 |
2292 forum posts 159 photos | If the machine is still in the not working condition do the following WITH THE POWER REMOVED. Disconnect the wires U1 and U2 from the motor terminals. (These are probably the run winding.) Measure the resistance between the teminals they were removed from. If you get a low reading Less than about 15 ohms then this is the run winding. (If you get a low reading go to step 2. If you get a very high or infinite resistance reading then this will be the start winding in series with the capacitor and centrifugal switch. With the meter leads still on the terminals short out the capacitor terminals. If the centrifucal switch is close (Which it should be with the motor stopped.) then the meter should give a low reading. ( Less than about 20 ohms.) If you still have a high reading then the centrifugal switch is faulty. Goto End. End. Report the results. Les.
Brian Wood | 09/12/2018 19:22:55 |
2742 forum posts 39 photos | Colin, Your starting fault is now beginning to sound like dirty points in the centrifugal switch; sometimes it makes and sometimes it doesn't. I would still change the capacitor to an up-rated version while you have the chance. Regards Brian |
Les Jones 1 | 09/12/2018 20:02:58 |
2292 forum posts 159 photos | Just reading though the post again we could be jumping the the conclusion that the motor is faulty. Nothing has been done to verify that the conractor KM1 is being energised. That needs to be checked next time the fault occures. Les. |
Jon | 09/12/2018 21:03:09 |
1001 forum posts 49 photos | Same motor as mine Colin. Seen similar endless times, what happens when you give the spindle a push start?
Colin Heseltine | 10/12/2018 14:25:18 |
744 forum posts 375 photos | Les, Carried out step 1. and get reading of 3.1 or 3.2 ohms across terminals (2 different test meters) Step 2 - NO reading on either of two meters. As I did not get a reading I did not short out the capacitor connections. Checked the contactors - they are pulling in Behave the same whether in forward or reverse. Also tried rotating the motor (via fan blades) whilst attempting to start - this did not have any effect. Colin
Edited By Colin Heseltine on 10/12/2018 14:38:18 |
Colin Heseltine | 10/12/2018 15:00:44 |
744 forum posts 375 photos | Further to last comments. I have just checked voltage coming into my home. My computer UPS is reporting todays voltages Min=242v, Max 248v. Over last months seen just over 250v several times. I am located about 20meters from substation, from which I have a 100amp 3 phase feed. One of my testers it appears can check capacitors. The readings appear to vary. Get values from 0.18nf through to 8.16nf The display then appears to microF then shows a value of 0. I have no idea how a nf compares to a microF Colin Edited By Colin Heseltine on 10/12/2018 15:24:55 |
Les Jones 1 | 10/12/2018 15:25:28 |
2292 forum posts 159 photos | When you say that you did not get a reading do you mean that you got an infinite reading ? An infinite (Or at least very high.) reading is what I would expect with the start winding in series wth the capacitor and centrifugal switch. The idea of shorting the capacitor out is so you measure the resistance of the start winding in series with the centrifugal switch, that should be quite low less than 20 ohms. I have no susspicion that there is any problem with your mains supply. Les. |
