Nickel plating
Former Member13/11/2018 21:44:00
1329 forum posts
Watford13/11/2018 22:35:04
142 forum posts
11 photos
Try Frost....................
https://www.frost.co.uk/paints-coating-plating/automotive-electroplating/electroplating-kits.html
Go to Plating Kits
Heard good results from vintage motorcycle restorer.
Edited By Watford on 13/11/2018 22:36:43
John Paton 113/11/2018 22:48:21
327 forum posts
20 photos
a friend of mine has been playing at nickel plating and says it is dead easy once you get a pure nickel source to plate from. His results look ok to me but time will tell how well it stands up. I think he just uses acetic acid as electrolyte and a small 5v power supply to drive it.
cleanliness is key
Former Member14/11/2018 08:34:41
1329 forum posts
Mark P.14/11/2018 08:53:38
634 forum posts
9 photos
Don't forget to dangle your bits to be plated off titainum wire.
Mark P.
Martin Whittle14/11/2018 09:33:11
102 forum posts
12 photos
I have used a kit from Gateros Plating with excellent results. They sell directly or on ebay.
The basic Watts bath gives a very matt grey finish; by adding the 'brightener' to the bath a fully bright shiny surface is achieved.
Polish and clean the work scrupulously before plating. It may be helpful to use solvents, then electrolytic cleaning - anodic cleaning is the most vigorous but not suitable for all metals as it can cause oxidisation of the surface (e.g. 'anodised aluminium' in the extreme case). Otherwise cathodic cleaning is good but slower.
Titanium wire (or mesh) is used to suspend the anodes; it does not matter too much what you suspend the work with as it will quickly get nickel plated!
Martin
mark costello 114/11/2018 17:42:08
800 forum posts
16 photos
Over here the junkyards buy old American nickles (coins) as the nickles are cheaper than buying commercial nickle.
Grindstone Cowboy14/11/2018 18:18:12
1160 forum posts
73 photos
Always had good service and advice from Classic Plating **LINK**
No cconnection other than as a satisfied customer.
Rob
Harry Wilkes14/11/2018 21:05:26
1613 forum posts
72 photos
This vid maybe worth a watch link
H
Fowlers Fury14/11/2018 21:39:10
446 forum posts
88 photos
Alternatively you could get this ~ much cheaper:-
