Terry Chapman | 01/11/2018 14:12:18 |
![]() 97 forum posts 14 photos | Hi,Ive got water coming into my oil box and had a look look at the one way valve and it seems the balls not sealing? Whats the best way to re seat bearing (excuse the pun) its about 1/8" diameter. Its off my 1" Minnie. Thanks |
RevStew | 01/11/2018 14:39:25 |
87 forum posts | Brass pin punch onto the ball and a sharp tap with a hammer works for me. |
Terry Chapman | 01/11/2018 14:56:47 |
![]() 97 forum posts 14 photos | Posted by RevStew on 01/11/2018 14:39:25:
Brass pin punch onto the ball and a sharp tap with a hammer works for me. Thanks,Ill give that a go?
HOWARDT | 01/11/2018 15:04:06 |
1081 forum posts 39 photos | Preferably use a new ball after re-seating as per RevStew. |
mechman48 | 01/11/2018 15:52:57 |
![]() 2947 forum posts 468 photos | Posted by RevStew on 01/11/2018 14:39:25:
Brass pin punch onto the ball and a sharp tap with a hammer works for me. +1 … always seems to be the preferred method. |
Dalboy | 01/11/2018 17:11:13 |
![]() 1009 forum posts 305 photos | Another way to do this is to solder a new ball onto a small shaft and apply very fine grinding past or burnishing cream and lap it as you would a car valve then replace the old ball with a new one after cleaning out |
Nigel Bennett | 01/11/2018 18:07:17 |
![]() 500 forum posts 31 photos | If the seat's not in too bad nick, you could also try a nitrile ball - Polly sell them. I've had a lot of good results with them. |
Jon Lawes | 01/11/2018 20:06:48 |
![]() 1078 forum posts | I'm tempted to try a nitrile ball in my water pump if only because it might help with the quality of my workmanship so far... |
Terry Chapman | 04/11/2018 13:50:28 |
![]() 97 forum posts 14 photos | I done the 'Tap' job and is all fine now thanks |
RevStew | 06/11/2018 19:40:28 |
87 forum posts | I've used that technique on hydraulic systems running up to 720bar. Now here's a thing. I wonder if such an arrangement would be more likely to leak with more pressure, or less pressure?! Anyone care to hazard a guess? |
