feedscrews
lee sargent | 20/09/2018 20:21:25 |
7 forum posts | appealing for some info on a ww83 leinin lathe sliderest...cannot identify thread on feedscrews.. hoping to make new nut for xslide..dia is 5mm , but not metric or ba..or even unf or bsf...pitch seems slightly coarser than 5mm metric...tried lathes.co...websites etc...totally stumped ...did german lathe makers use special threads..same situation with a screw holding lorch tailstock handle on..anyone help if poss please....thanks |
JasonB | 20/09/2018 20:35:11 |
![]() 25215 forum posts 3105 photos 1 articles | Looking at Lathes.co.uk they show handwheels with 80 divisions, that would equate to M5 x 0.8 which is standard metric coarse. Though if they have used a trapezoidal form and the standard pitch of tr5 is 1.0mm Have you put a DTI against the slide to see how far it moves with one turn of the handwheel and what divisions on the handwheel?
Edited By JasonB on 20/09/2018 20:56:35 |
Michael Gilligan | 21/09/2018 07:54:10 |
![]() 23121 forum posts 1360 photos | M5 x 0.8 seems entirely logical, Jason Apart from the Pultra and the Jason, none of my 'watchmaker' lathes has feedscrews As ever: If Lee could post a detail photo of an unworn section of the thread, I would be happy to try 'measuring' it. MichaelG. . http://www.lathes.co.uk/leinenmodern/ Edited By Michael Gilligan on 21/09/2018 08:11:49 |
JasonB | 21/09/2018 08:04:38 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Michael Gilligan on 21/09/2018 07:54:10:
I would be happy to try 'measuring' it. Would that be using your ipad "measure" app |
Michael Gilligan | 21/09/2018 08:16:49 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 21/09/2018 08:04:38:
I would be happy to try 'measuring' it. Would that be using your ipad "measure" app . The App that I use for these remote efforts is called 'EP Calipers' MichaelG. . P.S. "Optical Metrology" is not to be sneered at Edited By Michael Gilligan on 21/09/2018 08:27:24 |
lee sargent | 21/09/2018 19:38:10 |
7 forum posts | thanks for replies....those pics are of the slide I have...o.8 pitch it seems to be...all clues point to the shape of the thread... dont think a tap is available...screwcutting is out....tap could be made possibly...a shadowgraph would be ideal, but no access to one at mo, so its a bit more headscratching for me...thanks again |
JasonB | 21/09/2018 19:52:00 |
![]() 25215 forum posts 3105 photos 1 articles | From the photo Michael posted it does not look like anything special just a Vee form standard metric thread. Can you post a decent closeup photo of yours |
Michael Gilligan | 21/09/2018 20:28:09 |
![]() 23121 forum posts 1360 photos | Posted by lee sargent on 21/09/2018 19:38:10:
...a shadowgraph would be ideal, but no access to one at mo ... . But can you take a decent close-up photo of your thread ? MichaelG. . Did you notice the echo, Jason ? Edited By Michael Gilligan on 21/09/2018 20:30:12 |
lee sargent | 23/09/2018 01:49:30 |
7 forum posts | thanks again for help..not a standard m5 is the thread..tried several bolts..wont even go in one thread...cannot photo...no camera...wonder if its possible to contact leinin themselves..though metric is 60 degree thread, have suspicion it might be 55 or less..friend has some screwpitch gauges..might try them... |
Michael Gilligan | 23/09/2018 06:45:45 |
![]() 23121 forum posts 1360 photos | Posted by lee sargent on 23/09/2018 01:49:30:
... have suspicion it might be 55 or less..
. We're really into guesswork now Lee; but I suggest you try [gently] a 2BA screw for size. The BA threads were based on a Swiss thread in the first place; so it's not as improbable as you might think. MichaelG. . https://en.wikipedia.org/wiki/British_Association_screw_threads . Edit: Sorry ... I've just re-read your opening post, and you state that it's not BA Edited By Michael Gilligan on 23/09/2018 06:54:53 |
JasonB | 23/09/2018 07:09:05 |
![]() 25215 forum posts 3105 photos 1 articles | I see a new one has 1.0mm pitch and 100divisions, as you say ave a word with Boley to see if they can help, may even sell spare nuts. Could be Lowenherz thread as the 5mm dia one is 0.8pitch, 53.8deg Edited By JasonB on 23/09/2018 07:12:21 |
Brian Wood | 23/09/2018 10:28:41 |
2742 forum posts 39 photos | Jason, Sorry to correct you, but Lowenherz threads were 53 degrees and 8 minutes, not 53.8 degrees They were used by German and Austrian instrument makers into the early 20th Century so that thread form is a possibility. I imagine taps/dies to suit are now unobtainable. Perhaps Lee's best hope is to hot form a nut in Delrin from his thread and use that, suitably machined, to make a new feed nut Brian |
Bazyle | 23/09/2018 11:13:39 |
![]() 6956 forum posts 229 photos | There is no reason to suppose they would use a standard thread, it's not like they are going to make the leadscrew from a bit of allthread from the hardware store. More likely they thought of the pitch they wanted to use and the diameter that would be suitable and made them in-house. Making a suitable tap would be trivial for a machine tool maker. As well as trying an M5 nut did you try a screw in the feednut? It may be that it is close to standard M5 but depth or crest height is different, or it is the angle that is different in the way that UNC and Whitworth fit in one combination but not the other. |
Vic | 23/09/2018 11:23:06 |
3453 forum posts 23 photos | Posted by Michael Gilligan on 21/09/2018 08:16:49:
I would be happy to try 'measuring' it. Would that be using your ipad "measure" app . The App that I use for these remote efforts is called 'EP Calipers' MichaelG. . P.S. "Optical Metrology" is not to be sneered at Edited By Michael Gilligan on 21/09/2018 08:27:24 Very handy Michael, not seen that app before. |
lee sargent | 23/09/2018 23:34:51 |
7 forum posts | thanks again for replys..actually thought about making new screw an nut ..m5...but being long an thin would be a nightmare...friends Colchester has no steadies...one optionwould be to get aspare screw an nut for one of the mini lathes available..tho they are legion...!....would put dials out, but I dont really use them..saying that, they probably to large anyway..clearances only permit about 5mm...hmm...more headscratching.... |
JasonB | 24/09/2018 06:58:24 |
![]() 25215 forum posts 3105 photos 1 articles | If you are going down that route then think about getting a tr5 leadscrew and matching nut which would retain your dial readings and be the ideal thread form. |
