9/20 lathe motor is failing.
Dennis24/08/2018 15:49:20
13 forum posts
I have a 9/20 lathe about 30years old it has a 3/4hp motor I think 1750 rpm it has started to fail it hums when too much load is put on it and sometimes fails to start.I have another motor 1hp 2000rpm tryed and tested ready to go on but I worry about the the belts which are very thin and hard to find.Also what's the spindle speeds going to be.Anybody done this mod.
Pete Berry24/08/2018 16:40:41
28 forum posts
7 photos
Hi Dennis, have you checked the capacitor. Or capacitors if it is capacitor start capacitor run ?
Dennis24/08/2018 16:52:02
13 forum posts
No not yet how can tell if they are the problem.Also got a bit mixed up with the motor should be 3/4hp 1750 rpm and 1.1kw 2850rpm sorry.
John Rudd24/08/2018 16:58:10
1479 forum posts
The original motor was cap start with a centrifugal switch....well at least mine was equipped so.
I binned the motor in favour of a 3 phase job with a vfd.
I also bought spare belts from Beeline Engineering in Milton Keynes at very favourable prices over any other supplier ( such as Warco/Chester)
Shout up if you think I can help..
john fletcher 124/08/2018 16:58:28
893 forum posts
If 3/4 hp motor is the correct one stick with it, the mounting will be correct. I think the motor will be 1450 rpm which is quite usual for small lathes. It's not difficult to overhaul your motor, because I think you centrifugal switch might not be closing or if as Pete Berry says ,it could be the capacitor which is in series with switch and the start winding. Before dismantling, mark both end shield/bearing housing using a steel rule and scriber, two scratches across one end, one the other ,these marks will enable you to reassemble the motor more easily and ensure the rotor revolves freely. As the motor is quite old be very careful with those very thin internal wires. Regarding the capacitor there is no simple way to test it with out a meter. You maybe able to borrow one, the actual value is not critical for test purposes. John
John Haine24/08/2018 16:59:28
5563 forum posts
322 photos
Are you on a 60 Hz supply? 1750 rpm sounds funny for 50 Hz.
I'd just replace the cap(s) with modern equivalents as a first step. The symptoms sound like a dodgy start capacitor. The motors themselves are nearly bulletproof except for the bearings but they should be fixable especially if ball races.
What sort of motor is your 2000 rpm one? A 4 pole induction motor will run at 1800 rpm max (maybe 1750 actual) on 60 Hz and a 2 pole maybe 3500 on 60 Hz. Anyway it's only 14% faster than your present motor which is negligible. As for the power, people don't seem to appreciate that power is the MAXIMUM the motor can turn out when fully loaded. It doesn't deliver any more power than the job absorbs, so if your worry is the belts breaking with more power, if you don't take heavier cuts it's no more likely than with the current motor.
Pete Berry24/08/2018 17:07:08
28 forum posts
7 photos
As John says I would just try replacing the caps as it would be difficult to test them without test se
t
Dennis24/08/2018 17:12:58
13 forum posts
Hi Pete thanks for your reply just checked the lathe I think there's a loose wire connection it looks a bit black.thanks again.
larry phelan 124/08/2018 19:56:12
1346 forum posts
15 photos
As John said,these old motors are nearly bulletproof, most likely to be a cap problem,if so,just replace it,not that dear.
