John Purdy | 17/08/2018 21:48:54 |
![]() 431 forum posts 252 photos | Does anyone know if there are any suppliers of castings for Westbury's "Phoenix" 15cc engine? I've checked all the usual suppliers (that I know about) without success. John |
JasonB | 18/08/2018 10:11:17 |
![]() 25215 forum posts 3105 photos 1 articles | I have inquired with one of the motor boys who does have castings for quite a lot of the old engines as well as being the custodian of many of Westbury's own engines but it is not one he has castings for. |
John Purdy | 18/08/2018 18:16:47 |
![]() 431 forum posts 252 photos | Jason Thanks for your reply Jason. The reason I'm looking is I've been given a set of plans and part machined castings but the carb and flywheel castings are missing. I guess it will be fabrication time. The crank case, main bearings, cylinder, liner, con rod, and crank are all finished, and the machining appears to be of a high standard. The only problem is the crank appears to be slightly out of true and will require, I think, some judicious straightening. John |
