Martin King 2 | 10/08/2018 10:53:54 |
![]() 1129 forum posts 1 photos | Hi all, Have had this for some time but had no luck finding out what it is for. it came from a French vide grenier last year and is very well made as can be seen. I thought it was for some sort anethstetic use as it has "CHLORETYLE BENGUE' alng with the usual Brevette SGDG marks. However there is no venting hole or vavle to the top, it just comes straight off so all contents would be gone in a flash? Any thoughts are most welcome. Cheers, Martin |
Fowlers Fury | 10/08/2018 11:11:04 |
![]() 446 forum posts 88 photos | Ethyl chloride was and still is, used as a local anaesthetic e.g for piercing ear lobes and other bodily parts I prefer not to think about.
Michael Gilligan | 10/08/2018 11:21:05 |
![]() 23121 forum posts 1360 photos | Martin, What an interesting device ! After drawing blanks on various translation tools, and on google ... I tried searching with DuckDuckGo, and would recommend that you do the same. MichaelG. . Edited By Michael Gilligan on 10/08/2018 11:23:39 |
Martin King 2 | 10/08/2018 11:44:36 |
![]() 1129 forum posts 1 photos | Posted by Michael Gilligan on 10/08/2018 11:21:05:
Martin, What an interesting device ! After drawing blanks on various translation tools, and on google ... I tried searching with DuckDuckGo, and would recommend that you do the same. MichaelG. . Edited By Michael Gilligan on 10/08/2018 11:23:39 Michael. many thanks indeed, lots of info there including an exactly similar photo. Seems there were several different sorts of this device, i liked the one with different ends/nozzles. Cheers, Martin |
Martin King 2 | 10/08/2018 11:45:59 |
![]() 1129 forum posts 1 photos | Fowlers Fury: many thanks for the link, top does appear to be original as per one of Micheal's links. Cheers, Martin |
Martin King 2 | 10/08/2018 11:47:19 |
![]() 1129 forum posts 1 photos | Michael, FWIW this came in the bottom of a box of grubby scrap spanners! Wrapped in an old copy of a French newspaper! Martin |
Brian Wood | 10/08/2018 12:26:45 |
2742 forum posts 39 photos | Martin, I'm curious and don't want to explore on DuckDuckGo; I thought this was a drench tool or something similar. What is it please? Brian |
Neil Wyatt | 10/08/2018 12:35:17 |
![]() 19226 forum posts 749 photos 86 articles | As it boils at about 12.5C, perhaps it was partially filled with liquid which was allowed to evaporate and provide a mixture for general anaesthesia. A bit rough and ready by today's standards. Neil |
Martin King 2 | 10/08/2018 12:50:21 |
![]() 1129 forum posts 1 photos | Hi Brian, It is a portable way of allowing local anaethstetic to be administered, i guess by dropping it on a mask over the patients nose & mouth. I do not think it could last very long as it evaporates so fast? PS whats a drench tool? Cheers, Martin |
pgk pgk | 10/08/2018 13:00:53 |
2661 forum posts 294 photos | This would just be a storage tank. I've only ever seen ethylene chloride used for it's evaporative cooling effect.. in dentistry on a pledgelet of cotton wool applied to teeth when unsure which is the sensitive one or sprayed topically prior to minor surgery. This link to the anaesthesia journal describes it's general anaesthesia uses **LINK** I'm guessing it would have been dripped onto a simple face mask. Indeed in my youth it was common for vets to anaesthatise cats for minor procedures using a pledglet of ether soaked cotton wool dropped into the bottom of either a golden syrup or fowlers treacle tin which had multiple piercings in it's base. The patient would inhale through that base and cotton wool and vapourise the ether. There is an art form in controlling mutiple feline weaponry with one hand while hanging on to the scruff and holding tin over face with the other. After the procedure (typically a quick castration) the cat would be put back in it's basket and handed to the owner with instructions to drive home with the windows open a little - not enough for the cat to escape but enough to vent the cat's expirations lest the driver pass out.
pgk |
Fowlers Fury | 10/08/2018 13:07:47 |
![]() 446 forum posts 88 photos | "As it boils at about 12.5C, perhaps it was partially filled with liquid which was allowed to evaporate and provide a mixture for general anaesthesia." |
John Paton 1 | 10/08/2018 13:28:22 |
![]() 327 forum posts 20 photos | Fowlers Fury - that is interesting and a little worrying. I use ether both for 'pepping up' stale fuel for model diesel engines and also in the form of easy start for petrol engines. How much do you need to breathe in to cause a heart problem? Cheers John |
David Standing 1 | 10/08/2018 13:28:48 |
1297 forum posts 50 photos | Posted by pgk pgk on 10/08/2018 13:00:53:
pgk
That made me giggle |
Michael Gilligan | 10/08/2018 13:58:52 |
![]() 23121 forum posts 1360 photos | Posted by Brian Wood on 10/08/2018 12:26:45:
I'm curious and don't want to explore on DuckDuckGo . Any special reason, Brian ? ... Your comment has made me curious MichaelG. Edited By Michael Gilligan on 10/08/2018 14:17:45 |
Fowlers Fury | 10/08/2018 20:55:48 |
![]() 446 forum posts 88 photos | John Paton wrote: "that is interesting and a little worrying. I use ether both for 'pepping up' stale fuel for model diesel engines and also in the form of easy start for petrol engines. How much do you need to breathe in to cause a heart problem?" Pedantic P.S. for Neil, boiling point of chloromethane is: -24.2°C |
mike T | 10/08/2018 23:35:08 |
221 forum posts 1 photos | I was once clever enough to flatten my thumb with a hammer blow, made a right mess of the thumb nail. A medic at the local RN base treated my injuries. He had a small glass bottle of chloromethane which expelled a jet of the liquid as the liquid inside the bottle boiled off. The medic directed the jet ot liquid chloromethane at my damaged thumbnail. Intensely cold at first but I soon lost all sensation, moments later he removed the complete thumbnail. All over and done within a few minutes, I did not feel a thing. He said I was lucky, in a previous era I would have been given a piece of wood to bight on instead.or perhaps a tot of rum. |
Neil Wyatt | 11/08/2018 00:11:50 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Fowlers Fury on 10/08/2018 20:55:48:
Pedantic P.S. for Neil, boiling point of chloromethane is: -24.2°C Pedantic from me - we're talking about chloroethane not chloromethane... Neil |
Brian Wood | 11/08/2018 08:52:38 |
Michael G I picked up a computer bug from somewhere recently, despite the care taken with firewalls and the like and I was doubtful about the name DuckDuckGo----there was no other reason
Martin King 2 A drench is I believe a flushing device to which a piece of hose is attached and used as the name implies for irrigation purposes; it was the cross handle on top of your device that led me to thinking it might be a one shot pump action applicator. Vets also apply a drench to cattle and other ruminants by pouring the mixture down a rubber tube with a filling funnel attached, the mixtures are mostly for re-hydration Regards Brian |
Michael Gilligan | 11/08/2018 10:28:28 |
![]() 23121 forum posts 1360 photos | Posted by Brian Wood on 11/08/2018 08:52:38:
Michael G I picked up a computer bug from somewhere recently, despite the care taken with firewalls and the like and I was doubtful about the name DuckDuckGo----there was no other reason . Thanks for the clarification, Brian Due caution is always advisable, given the world we live in. To the best of my knowledge DuckDuckGo is simply a very good search engine, built by people with very good intentions. ... I like it a lot. If you are still comfortable using Wikipedia, may I suggest that you look at this: **LINK** https://en.wikipedia.org/wiki/DuckDuckGo MichaelG. |
Fowlers Fury | 11/08/2018 12:20:17 |
![]() 446 forum posts 88 photos | "Pedantic from me - we're talking about chloroethane not chloromethane..." Mike., mea culpa and apology. In mitigation, I was schooled in the old chemical nomenclature of methyl/methylene, ethyl/ethylene, propyl/propylene etc followed by the attached halogen radical. Before my retirement IUPAC decided to change it all by putting the radical first & calling them halogenoalkanes. So ethyl chloride became chloroethane and so on. Aged brains like mine had to cope with usage of both names, often leading to carelessness as in reading the b.p. of chloromethane instead of chloroethane. (Unless watched, spell checkers will “correct” one’s “errors” as typing this has proven). |
