Alan Waddington 2 | 04/08/2018 17:22:08 |
537 forum posts 88 photos |
ok, ive got the basic diagram, but no amount of web trawling brings up a diagram showing a start capacitor and centrifugal switch. Can anyone do me a diagram showing how to connect these into the circuit. Have had it running both forward and reverse, but running for a minute or so in reverse blew the start cap, so i’m guessing how i had it wired wasn’t dropping the capacitor out when reversed. This is the basic schematic im using. TIA.......been at it a couple of hours now with no joy, and ive gone wire blind now |
NJH | 04/08/2018 17:34:34 |
![]() 2314 forum posts 139 photos | Hi Alan Have a look in my photos for one called “Myford Reversing” - all should then be clear Norman Edited By NJH on 04/08/2018 17:35:21 |
Les Jones 1 | 04/08/2018 17:51:19 |
2292 forum posts 159 photos | The main winding is connected to terminals 5 and 7 on the Duhurst switch.. The start winding with the centrifugal switch and capacitor in series with it connect to terminals 2 and 6 on the Dewhurst switch. You may need to post pictures of the connection box on your motor if the above information is not clear. Les. |
Alan Waddington 2 | 04/08/2018 17:53:46 |
537 forum posts 88 photos | Posted by NJH on 04/08/2018 17:34:34:
Hi Alan Have a look in my photos for one called “Myford Reversing” - all should then be clear Norman Edited By NJH on 04/08/2018 17:35:21 Cheers Norman, but im still not getting it |
Alan Waddington 2 | 04/08/2018 18:00:35 |
537 forum posts 88 photos | Posted by Les Jones 1 on 04/08/2018 17:51:19:
The main winding is connected to terminals 5 and 7 on the Duhurst switch.. The start winding with the centrifugal switch and capacitor in series with it connect to terminals 2 and 6 on the Dewhurst switch. You may need to post pictures of the connection box on your motor if the above information is not clear. Les. Mmhh, that’s how i thought i had done it.......will have to order a new capacitor and try again. Thanks for the help chaps, will report back in due course.
JohnF | 04/08/2018 19:06:20 |
![]() 1243 forum posts 202 photos | Alan W please PM me with your email and I'll send you the original info on PDF files -- would put it on here but cannot up load PDF's plus maybe infringe copyright ? John |
Alan Waddington 2 | 11/08/2018 17:34:32 |
537 forum posts 88 photos | Just an update, to thank everyone for their help. Turns out i had wired it correctly, must have just been bad luck that the capacitor decided to self destruct. Fitted a new one this morning, and checked with meter that it was dropping out in both forward and reverse directions.......All good, and no smoke escaping. |
