Mick Whiley | 10/07/2018 22:25:25 |
5 forum posts 16 photos | Hi, I have just an ML7RB made in 1993, obviously little used as it still has a lot of the protective grease on it. After 25 years this grease has hardened and reluctant to come off. It is on both painted and machined surfaces. I've tried the toothbrush and paraffin sketch but made very little headway. Willing to listen to any ideas, obviously don't want to spoil the paint.
Michael Briggs | 11/07/2018 00:18:46 |
221 forum posts 12 photos | Hello Mick, for the machined surfaces I would cover with a rag or kitchen roll then apply paraffin or white spirit. Cover with cling film to slow evaporation and leave for 24 hrs, hopefully that will soften the grease. For painted surfaces the usual do a test piece first. Regards Michael. |
lou | 11/07/2018 00:19:28 |
2 forum posts | Hello, I found out that metal polish worked excellent on my old Clausing lathe. The brand I used was Tarnite. Although I believe they are out of business now. Maybe another brand that is a tarnish remover. It removed the 40 year old dried on cutting oils. Lou
Hopper | 11/07/2018 07:49:59 |
![]() 7881 forum posts 397 photos | Have you tried WD40? That dissolves a surprising range of gunk. Or automotive degreaser? Petrol will dissolve most gunky things if you get desperate, but is a terrible fire hazard. Ventilate well and have all electrical equipment switched off if you must use it. Edited By Hopper on 11/07/2018 07:50:20 |
Neil Wyatt | 11/07/2018 17:34:19 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Hopper on 11/07/2018 07:49:59:
Have you tried WD40? That dissolves a surprising range of gunk. Or automotive degreaser? Petrol will dissolve most gunky things if you get desperate, but is a terrible fire hazard. Ventilate well and have all electrical equipment switched off if you must use it. Edited By Hopper on 11/07/2018 07:50:20 White spirit will work as well as petrol, but slower and less risky. I used it to get an amazing amount of thick grease off the SC4-500 faceplate. Several day's soak in a wash basin with the stuff. Neil |
