safest way to hold
mick7005/07/2018 15:31:13
524 forum posts
38 photos
got some rear bike hubs that very sturdy i want to modify to use on tadpole builds.
one is threaded internally to hold freehub.
i want to bore that out and remove spoke flange from it.
then make piece that fits in place with disc brake holder and larger soke flange on it.
reason for doing it is not easy or cheap to get hub i can fit bearings and 14mm axle to.
Bob Stevenson05/07/2018 17:23:01
579 forum posts
7 photos
About 30 years ago when mountain bikes were still quite rare I was seriously into making custom hubs and also made several sets for patent applications and evaluations....I still have some somewhere. There are several pifalls for the unwary designer....... The brake coupling method really need to be integral with the hub so you may well be much better off going straight to machining original hubs and NOT trying to make a hybrid brake fitting for your existing hub. Both discs and drum brakes are extremely dificult to design and engineer because of the unique operating 'envelope' of off (or 'on' come to that) road biking....it's tiresome to experience catastrophic wheel failure withng feet of the door time and time again after many hours of wheel building and adjustment.......
........Another major challenge is the design, profile and placement of teh spoke holes on the 'large' side of the wheel.
JohnF05/07/2018 17:25:43
1243 forum posts
202 photos
Holding fixture needed here Mick, is the main bore [last photo] machined and concentric to the other machined parts? If so i would make an expanding mandrel thats reasonably close to the threaded part you intend to remove, you can then bore these out and remove the spoke flange, add what you want and machine that as well if need be.
PS heed Bob's warning life and limb at stake !
Edited By JohnF on 05/07/2018 17:28:06
mick7005/07/2018 19:23:27
524 forum posts
38 photos
Point taken Bob will start from scratch.
John will look out for expanding mandrel as if starting from scratch will hold OD and bore center out to size then do outside.
JohnF05/07/2018 21:19:42
1243 forum posts
202 photos
Expanding mandrels are easy to make, turn to the size you need, drill and tap for the largest countersunk allen screw that will fit - bigger the head the better. Then saw 4 or better 6 slits down the mandrel so that when you tighten the screw it expands - job done! Obviously de-burr the saw cuts and a slight counterbore at the end of the thread helps the screw to seat properly.
Bodger Brian05/07/2018 21:47:57
187 forum posts
40 photos
Posted by mick70 on 05/07/2018 15:31:13:
Just curious - in this context, what is a tadpole?
Mike Poole05/07/2018 22:37:02
3676 forum posts
82 photos
I think a Tadpole is a recumbent trike.
Michael Gilligan05/07/2018 22:43:57
23121 forum posts
1360 photos
Brian,
A look at this recent thread will probably help: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=136343
