Rotary table set up
BOB BLACKSHAW27/06/2018 20:58:53
501 forum posts
132 photos
I am thinking of making some type of jig to set up a rotary table on a mill. I thought of using a plunge DTI on a lump of aluminum bolted to the rotary table so that it rests on the mill spindle.
How do you set up a rotary table, as in the past its taken me ages to get a reasonable set up.
If this has been discussed in past threads, apologies to all.
Bob.
Mike Clarke27/06/2018 21:08:26
95 forum posts
Hi Bob,
I use a large ball bearing (approx 30mm) - lower the quill and trap the ball bearing between the centre of the rotary table (presuming you have a hole there!) and your milling chuck, for example.
Works for me.
Cheers,
Maurice27/06/2018 21:11:12
469 forum posts
50 photos
I assume that you wish to set the centre of the rotary table in line with the axis of the mill spindle. I use a morse tapered mandrel with an accurate 1/4” reamed hole in it, and a length of 1/4” sliding in it with a circling to stop it falling right out. A piece of steel is fitted in the centre of the rotary table, also with a 1/4” hole reamed in it. Having clamped the rotary table approximately under the spindle, then move the mill table until the rod drops freely into the hole. If in any doubt, check it after with a DTI.
Maurice
mark costello 127/06/2018 22:03:57
800 forum posts
16 photos
Excellent,Mike.
Andrew Johnston27/06/2018 22:27:50
7061 forum posts
719 photos
Step 1: Set, and lock, the rotary table on zero.
Step 2: Lightly bolt down the rotary table, indicate on one of the four slots while moving the appropriate table axis. Tap the rotary table to reduce indicator movement, when the indicator doesn't move tighten the bolts.
Step 3: Use one of these:
in conjunction with the parallel hole in the centre of the rotary table to set the DRO on 0,0. For those who don't recognise the unit it's a Haimer Centro.
Having completed all steps the rotary table will have its cardinal points aligned with the X and Y movements of the mill, and the DRO indicates the centre of the rotary table. Doesn't take long, probably a few minutes.
Edited By Andrew Johnston on 27/06/2018 22:28:16
DMB27/06/2018 23:28:15
1585 forum posts
Alright for those able to boast about such large balls.
Sorry, couldn't resist that.
Where's me coat?
Jim Nic27/06/2018 23:45:31
406 forum posts
235 photos
I use a 2MT mandrel in the centre of the rotary table as per Maurice, albeit with a 10mm rod.
I loosely position the rotary table on the mill table with the rod inserted in the mandrel then tighten it down.
Jim
