choochoo_baloo | 04/06/2018 14:26:23 |
![]() 282 forum posts 67 photos | Hello all, A beginner question: I recently bought a Harder & Steenbeck airbrush. However now that I'm planning to repaint some aluminium castings, using a proper non-ferrous etch primer, I'm loath to use this airbrush to apply said etch primer due to it's chemical behaviour. Therefore, do others use a cheap second airbrush for applying such primers. Can someone recommend a particular model? Thanks in advance. |
Clive Brown 1 | 04/06/2018 14:54:51 |
1050 forum posts 56 photos | I've used the fairly cheap Badger basic airbrush with Precision Paints etch primer for an Allchin TE and a 5" Simplex. I also use it for normal enamels. I've not noticed any discernable effect from the etch primer and I'd probably use it with my more expensive DeVilbiss airbrush if need be. Thorough cleaning after use is obviously needed. Edited By Clive Brown 1 on 04/06/2018 14:56:20 |
Baz | 04/06/2018 15:00:43 |
1033 forum posts 2 photos | A few of us were discussing this at a recent club night and the general consensus was to use a cheap airbrush for acid etch primer. I use an old Badger 200 for etch primer. |
the artfull-codger | 04/06/2018 16:52:20 |
![]() 304 forum posts 28 photos | I paint quite a lot of alluminium castings mainly plaques & signs etc and also my models brass alloy steel etc, I'm fanatical about cleaning my brushes sprayguns & airbrushes, & I prime with ICI acid etch primer [don't think it's available any more] but I allways brush it on as it's thin & doesn't leave brush marks or runs, you can't tell if it's brushed or sprayed, my brush is immediately washed out in cellulose thinners, I use celly thinners for cleaning house painting brushes as well much superior to white spirit. |
Neil Wyatt | 04/06/2018 19:17:26 |
![]() 19226 forum posts 749 photos 86 articles | Do what I did about an hour and half ago - use an aerosol? |
the artfull-codger | 05/06/2018 18:41:21 |
![]() 304 forum posts 28 photos | Hmmn 2 pack acid etch primer from an aerosol Neil? Graham. |
choochoo_baloo | 05/06/2018 19:12:48 |
![]() 282 forum posts 67 photos | Posted by Neil Wyatt on 04/06/2018 19:17:26:
Do what I did about an hour and half ago - use an aerosol? You're probably right Niel, simpler to use aerosol etch primer. Please specify the product you use - ideally I'd like to use one for al of: brass, nickel-silver and aluminium-based casting on Myford. |
John Reese | 06/06/2018 00:32:07 |
![]() 1071 forum posts | Would something like this work? https://www.amazon.com/Critter-Spray-Products-22032-Siphon/dp/B00006FRPJ/ref=sr_1_15?ie=UTF8&qid=1528241362&sr=8-15&keywords=paint+spray+gun
It would seem a relatively simple job to make one starting with a blow gun. |
