Wanner Oil Gun
help please
Roderick Jenkins14/04/2018 16:27:45
2376 forum posts
800 photos
Hi Chaps,
My Wanner 300-4 oil gun, after 40 odd years of sterling service, has started leaking oil from its various orifices. I assume that a seal somewhere has perished. Before I start dismantling this rare and expensive beast, has anyone any experience of refurbishment? Please!
TIA,
Rod
Andy Holdaway14/04/2018 17:44:00
167 forum posts
15 photos
Rod,
This post on Australia's Woodworking forum should help.
Andy
Roderick Jenkins14/04/2018 18:12:37
2376 forum posts
800 photos
Andy,
Thanks, that's useful. Google didn't pick that one up!
Cheers,
Rod
Roderick Jenkins24/04/2018 16:25:10
2376 forum posts
800 photos
Thanks to Andy's link I have been able to register with what is now the Metalworks forum in Oz and see some pictures **LINK** . This gave me some very useful tips. Here's what happened to me, my gun is subtly different to Anorak Bob's:
When I was using the gun oil was jetting out from between the larger and smaller black tubes as well as the brass tube interface.
The normal filler cap came off, the washer is rubbery seal
Inside the main body, the cup washer is prised out to reveal this fancy nut screwed to the end of the smaller black tube. I made a crude pin spanner. The pins have to be long to enable enough of the smaller black tube to be gripped.
This is what comes out
The nozzle end now has to be unscrewed to allow the brass tube to be withdrawn
I've finally got to the problem - an O ring that has become hard and flattened. It was quite difficult to remove and I ended up digging it out with a scriber.
My small collection of O rings had something that looked suitable - this one is, as far as I can measure it, is 13mm OD x 1.8mm thick.
Reassembled and it all works, the oil goes where it should. The tapered end of the main barrel also unscrews, even though it is not knurled but, in retrospect, I do not think it is strictly necessary to remove this to change the seal
So, thanks to Andy Holdaway and Anorak Bob smiley. I hope this helps somebody else.
Rod
Michael Gilligan24/04/2018 17:15:34
23121 forum posts
1360 photos
Well done, Rod ... Thanks for sharing the fix.
Bill Dawes24/04/2018 19:24:42
605 forum posts
I have a Wanner grease gun, bought it brand new in my early days of motoring so must be about 55 years old. (cars had lots of grease nipples in those days!) Never done a thing to it as far as I can remember.
No idea how much I paid for it (how did I afford it come to that) must have been a genuine Wanner, I don't think far eastern fakes existed in those halcyon days.
Bill D.
Howard Lewis28/04/2018 12:43:04
7227 forum posts
21 photos
Still using (not often now) a cheap side lever grease gun that I bought for 12/6 (62p) in North London, back in the very early 60s. It still functions well, despite having had at least 15lbs (7 Kg) of grease put through it. Think I got a bargain!
Still use, occasionally, a "bendy bar" 1/2" drive torque spanner, again, bought for 12/6, in the mid 60s. Amazingly, at every check, over the years, it is accurate, more than one supplied by one of the most revered names in hand tools!
