Malcolm Farrant | 09/04/2018 09:21:40 |
102 forum posts 3 photos | According to L C Mason Reeves used to keep suitable cable for the Minnie, but they do not now. Any suggestions as to what cable to get. It seems, according to Mason, I need about 7 yards. Is that correct. Many thanks to all Malcolm Farrant |
roy entwistle | 09/04/2018 09:27:05 |
1716 forum posts | Any of the clock material companies. A long case clock uses 21 feet. A Vienna regulator will use less Possibly model aircraft shops. Tethered flight etc Roy |
JasonB | 09/04/2018 09:29:09 |
![]() 25215 forum posts 3105 photos 1 articles | I've used these people a few times. The 7x7 stainless will wrap around the drum OK.
They also do 1.5mm thimbles if you don't fancy making your own.
Edited By JasonB on 09/04/2018 09:33:53 |
Malcolm Farrant | 09/04/2018 17:20:13 |
102 forum posts 3 photos | Thank you both for your suggestions. Jason, I have had a look at the web site there is under the 7x7 very many thicknesses. Would you suggest the 1mm or thinner. Equally not sure if they sell by the meter or by spacific drum lengths. Yeas the 1.5mm thimbles might be a very good idea. Very best and thank you both again Malcolm |
Neil Wyatt | 09/04/2018 17:43:15 |
![]() 19226 forum posts 749 photos 86 articles | Google "stainless steel trace wire" and you may find something suitable. |
JasonB | 09/04/2018 18:42:59 |
![]() 25215 forum posts 3105 photos 1 articles | Just measured my Reeves supplied cable at 1.48mm so the 1.5mm from tecni-cable will be fine. Quantities in the box are for 1m @ 41p per mtr. for the 7x7 strand or 76p per mtr for the even more flexible 7x19 strand
duncan webster | 10/04/2018 20:04:52 |
5307 forum posts 83 photos | Bicycle brake or gear selector cable? The gear selector stuff is thinner. My locol bike shop sells it by the yard |
Bazyle | 11/04/2018 00:09:55 |
![]() 6956 forum posts 229 photos | It is a 1/12 scale model so I think 1.5mm would scale to a sensible size but go for the finer strand version as a full size cable with only 7 strands wold look a little clunky. |
JasonB | 11/04/2018 07:25:13 |
![]() 25215 forum posts 3105 photos 1 articles | Bazyle, they don't do a 7 strand, the 7x7 has 49 strands and the 7x19 has 133 strands. They also do a 19 strand but that is not very flexible which is why I did no suggest that because it will be like a spring wound around the 3" dia drum. |
Raymond Griffin | 11/04/2018 08:00:19 |
65 forum posts 48 photos | I recently purchased a length of cable for my I” Minnie from Blackgates Engineering. It is 1.5mm in diameter, very supple and will do nicely. I can’t remember the cost, but certainly not worth haggling about. Ray |
Neil Wyatt | 11/04/2018 09:08:43 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 11/04/2018 07:25:13:
Bazyle, they don't do a 7 strand, the 7x7 has 49 strands and the 7x19 has 133 strands. They also do a 19 strand but that is not very flexible which is why I did no suggest that because it will be like a spring wound around the 3" dia drum. My thinking behind trace wire, it is very flexible. Full size cables would have dozens and dozens of strands. |
Malcolm Farrant | 11/04/2018 12:26:21 |
102 forum posts 3 photos | Yet again very, very many thanks to everyobne for your input. I ha\ve gone with Jason's suggestion and am using Techni-Cable,. In conversation with them I was impressed by how very helphul they were. As suggested by Jason I have also bought the thimple from them. As a passing comment I am just so impressed with how helpful everyone is. Alas I seem to have a steady stream of question and problems and evey time i seek help i get an instant helpful response. A big thank you best wishes Malcolm
duncan webster | 11/04/2018 15:08:46 |
5307 forum posts 83 photos | Malcolm, I've sent you a PM |
