R Lenagh | 22/03/2018 15:51:21 |
3 forum posts | Hi, I recently bought a quantity of Silver solder that came along with several boxes of " Eutecrod 1600FC " flux coated "silver bearing" 3/32" rods. I like to know what I'm using and have been unable to find anything out regarding these rods. Not surprising given the phone number on the boxes is " Feltham 6571". While the flux coating is in a pretty poor state, I did try one on a piece of copper using just a Primus 2000 propane torch and it flowed beautifully. Any information regarding the content / use for, these rods would be welcome, Thanks. |
Brian Sweeting | 22/03/2018 23:04:51 |
453 forum posts 1 photos | Couldn't find the 1600FC but find lots of others. Maybe a call to the supplier is in order.. One description was talking about annealing at 1600°F - coincidence perhaps?
https://www.castolin.com/en-CA/productkeywords/EutecTrode
Keith Hale | 23/03/2018 10:28:27 |
![]() 334 forum posts 1 photos | Eutecrod is/was a tradename used by Castolin/Eutectic Company. 1600 is described on page 72 of their data book as a high temperature, wide melting range, low silver content alloy. This book came into my posession in the early 70's when I worked for Johnson Matthey. The information indicates to me that it is an alloy that cannot be neither sold legally nor "placed on the market" (ie given away) legally.. I would not expect it to have the brazing characteristics you have described. It doesn't do what it says on the tin! Leave it with you. You seem to have bought a "pig in a poke!" Worse case scenario is that it could shorten your life expectancy. Bargain? Regards Keith |
R Lenagh | 23/03/2018 17:55:03 |
3 forum posts | Thank you Brian, That's what I found, just about everything but the one you want. As is the way with these things, after posting on here I found this on ebay " EUTECTIC WELDING ALLOYS LTD NORTH FELTHAM WELDING ALLOYS PRODUCT CATALOGUE c1960 " This shows the 1600 as a " Special Silver Alloy " Rod having a " Medium to low melting " range. The search continues. Thanks again for your reply. |
R Lenagh | 23/03/2018 18:15:05 |
3 forum posts | Hi Keith, Hmmm, stranger and stranger.The quality of the company literature doesn't seem to match that of their product by the looks of it.In 1970 I had just come out of my time and I've used the odd rod or two since then, fear not, I shall take care. Thanks for taking the time to give what information you have. |
