Hillclimber | 13/03/2018 14:18:10 |
![]() 215 forum posts 51 photos | Any advice on fitting Python file handles? I've decided I'm too old to enjoy using the few rubbery-plastic ones I have - too pyongy. Hence a regime shift in favour of Python. Is there anything particular I need to know about the 'hidden spring'? Best to drill out a bit? Or just use the 'hot tang' burn-in method? Cheers, Colin |
Vic | 13/03/2018 14:48:30 |
3453 forum posts 23 photos | Where I used to work they just “ shoved it in” |
old Al | 13/03/2018 14:56:29 |
187 forum posts | Hot tang always works for me |
Nick Hulme | 13/03/2018 15:31:52 |
750 forum posts 37 photos | Push the file in as far as you can under your own steam then bang the file handle down firmly on a smooth surface with plenty of mass, I use my anvil, a few sharp strikes and I've never had one fall out. |
Clive Foster | 13/03/2018 15:36:57 |
3630 forum posts 128 photos | Some discussion here :- **LINK** Multistep process seems bit long winded but does, theoretically, avoid over-burning the hole. Theory of the spring is that it forces the softwood handle around the final part of the tang under the ferrule giving a good grip without needing to burn the big end of the hole to shape. Sort of thing you need to do to make a cheap, relatively crappy, handle work. Back in ye good old days with proper turned brass ferrules the handle cost around half as much as the file so you looked after it and expected it to do several files. Of course a file was a days wage or so too. Was years before I could justify new files as opposed to reconditioned ones via Mr Whistons (in)famous Cat on its log. Clive |
Hevanscc | 13/03/2018 22:52:54 |
89 forum posts 33 photos | You should push the tang into the handle and then, holding the wooden handle with the file facing down, strike the end of handle with a mallet. Somewhat counter-intuitively, this will force the tang into the handle rather than knock it out. You can look up the physics if you don't believe me. Hywel |
Hevanscc | 13/03/2018 22:53:05 |
Hillclimber | 14/03/2018 08:42:25 |
![]() 215 forum posts 51 photos | *Newton's third law* |
