Boiler end plates.
Joe King | 09/03/2018 16:14:07 |
3 forum posts | Do boiler end plates need to be flanged please ? |
JasonB | 09/03/2018 18:25:30 |
![]() 25215 forum posts 3105 photos 1 articles | A lot will depend on the size of boiler, material and method of jointing so hard to say without more details.
J |
Joe King | 09/03/2018 18:40:00 |
3 forum posts | Say 16swg copper tube between 50mm to 100mm diameter as in the simple low pressure model steam engines. I had copper discs for the ends in mind say 3mm thick and silver soldered. Hope this clarifies a bit , |
Neil Wyatt | 09/03/2018 20:31:05 |
![]() 19226 forum posts 749 photos 86 articles | A 16 to 14 gauge disc, flanged and slightly domed with a robust centre tube or stay would be normal at 100mm. Neil |
mick H | 09/03/2018 20:31:49 |
795 forum posts 34 photos | Published designs of most Gauge 1 boilers with 60psi working pressure and boiler diameter 50mm + are usually copper discs let into the boiler tube and silver soldered or just simply butted up against the boiler tube and silver soldered. I usually use 2.5 - 3mm thickness. Mick |
Joe King | 10/03/2018 08:31:58 |
3 forum posts | Thank you |
