Kealan O'Carroll | 01/03/2018 11:29:22 |
9 forum posts 6 photos | Hello chaps,
[img]https://i.imgur.com/0cmKwYR.jpg[/img] [img]https://i.imgur.com/yT0r2ZX.jpg[/img] [img]https://i.imgur.com/GF0Xl66.jpg[/img] [img]https://i.imgur.com/UqwlcQ9.jpg[/img] [img]https://i.imgur.com/Pe1ZxLl.jpg[/img] [img]https://i.imgur.com/kBmXe9D.jpg[/img] [img]https://i.imgur.com/1DmQ1Ji.jpg[/img] [img]https://i.imgur.com/SYHh49D.jpg[/img] [img]https://i.imgur.com/R5AGs3h.jpg[/img] [img]https://i.imgur.com/KmgSYzv.jpg?1[/img] [img]https://i.imgur.com/R5AGs3h.jpg[/img] [img]https://i.imgur.com/YpWNK3g.jpg[/img] Edited By JasonB on 01/03/2018 13:11:23 |
David Standing 1 | 01/03/2018 12:37:57 |
1297 forum posts 50 photos | Welcome Your images don't work as posted. You either need to edit them and take out the [img] and [/img] tags and then insert a http link per the icons above your post, or post them into a photo album here and link them from that |
Kealan O'Carroll | 01/03/2018 12:50:50 |
9 forum posts 6 photos | Bear with me! https://i.imgur.com/KmgSYzv.jpg?1
David Standing 1 | 01/03/2018 12:57:08 |
1297 forum posts 50 photos | Working now |
larry Phelan | 01/03/2018 13:16:34 |
![]() 544 forum posts 17 photos | Looks like a fairly hefty bit of kit ! Would love to hear how it shapes up. |
Phil Whitley | 01/03/2018 13:53:44 |
![]() 1533 forum posts 147 photos | When you get it set up on its legs, send a pic to [email protected] or have a troll through the worlds biggest machine tool archive at www.lathes.co.uk. Very well made machine by the looks of it, and gap bed too! Good luck! |
Howard Lewis | 01/03/2018 15:40:24 |
7227 forum posts 21 photos | Looks to be a useful machine, especially if you can find the changewheels to connect mandrel to the gearbox / leadscrew. Keep us abreast of your progress, please! Howard |
Kealan O'Carroll | 02/03/2018 20:42:57 |
I've got around 8 changewheels for it, but haven't checked the numbers yet (I did see a 127) so I'm not sure what pitches I can cut yet. The carriage does get tight when the tailstock is off and it's moved right down to the end of the ways, so they're probably worn but if I'm spending most of my time within 6 inches of the chuck then I'm thinking it may not be an issue? I ran it and made some chips from a scrap bolt I had laying about...at least it runs! I have a load of HSS blanks I got with it, but some of the smaller ones are lost in the toolpost and the larger bits that do actually fit the toolpost are ground miles above centreline. It's dead quiet with just the spindle running, but the tumbler is horrendously noisy when engaged in either direction, as is the powerfeed speed selector gearbox. The 3 - jaw also took both hands on the key to budge, so I took the jaws out and the spiral & the jaws are all gummed up in what looks like old dried up grease so that will need stripping and cleaning. The half nut and, handwheel, and slides all have a lot of backlash too; I don't know if this will actually be an issue or if I can just go beyond my start point and take up the backlash to work around it?
http://www.model-engineer.co.uk/albums/member_photo.asp?a=47788&p=792983 |
Michael Gilligan | 02/03/2018 20:57:13 |
![]() 23121 forum posts 1360 photos | Kealan, I will be very interested if you find the maker ... because it looks rather like a 'big brother' to my own mystery lathe: The inboard tumbler reverse arrangement should help with identification ... but I've got nowhere yet. MichaelG. . Yes, I do have the rest of it. |
Michael Gilligan | 02/03/2018 21:36:06 |
![]() 23121 forum posts 1360 photos | IXL/Ehrlich looks promising: **LINK** http://www.lathes.co.uk/ixl/ MichaelG. |
