Philws | 03/02/2018 23:43:28 |
2 forum posts | I am looking for suggestions on making a taper reamer for woodworking. The reamer needs to go up to 35mm with a 6deg taper. Any advice on the best way to achieve this would be appreciated. I also want to qualify to use the classifieds Phil |
Emgee | 03/02/2018 23:53:11 |
2610 forum posts 312 photos | Hi Phil, what size is the small end, or what length flutes do you need ? Emgee |
JasonB | 04/02/2018 07:46:46 |
![]() 25215 forum posts 3105 photos 1 articles | Simple method would be to turn your taper on a piece of silver steel and then mill away half the diameter and then harden & temper. This method is often used for cutting tapers in steam fittings though you will get some tearing in wood depending on grain direction. Could be cleaned up with abrasive paper wrapped around a similar tapered plug. |
ega | 04/02/2018 10:09:52 |
2805 forum posts 219 photos | Is the reamer wanted for making a musical instrument? I am fairly sure that process has been covered in The Woodworker magazine. |
John Reese | 05/02/2018 20:47:37 |
![]() 1071 forum posts | A chairmaker's reamer can be pretty simple to make as shown here: |
Simon Collier | 05/02/2018 22:17:48 |
![]() 525 forum posts 65 photos | Great photo, Jason. |
