Brass Tube
What grade is "steam pipe"?
Mike Crossfield28/01/2018 12:35:00
286 forum posts
36 photos
I need an 8 inch length of 2 inch diameter 16 or 18 gauge brass tube (to fill with lead for the pendulum of a clock I am making). My usual supplier of clock making brass sells CZ121 at around £2.50 per inch, but I've seen others selling 16 gauge brass steam pipe for 1/2 the price. Does anyone know what grade this would be, and if there is a snag to using it in my application?
John Haine28/01/2018 12:46:12
5563 forum posts
322 photos
Only snag I can think of is that the grade might not be very machinable but you wouldn't be doing much of that other than maybe squaring off the ends. I'd go for it myself.
Bazyle28/01/2018 14:52:53
6956 forum posts
229 photos
If getting it mail order be sure to mention that is to be used in a decorative role and must be free of dents. A clock supplier might be worth the extra for this and I can only think brass steam pipe must be left over from Mamod boiler making,
You could look into rolling it from sheet.
Edited By Bazyle on 28/01/2018 14:54:43
Billy Bean28/01/2018 15:03:00
174 forum posts
Maccmodels can supply
2 inch diameter by 16swg - they list an 8.5 inch length at £8.39 plus post.
Hope this helps.
BB
Mike Crossfield28/01/2018 18:12:27
286 forum posts
36 photos
Yes, Maccmodels was the supplier that triggered my question. Unfortunately they don’t state the grade of brass.op
Billy Bean28/01/2018 18:45:00
174 forum posts
Posted by Mike Crossfield on 28/01/2018 18:12:27:
The reason why I mentioned it was that I was the buyer who asked if they could supply an 8 inch length as opposed to a 12 inch length and Joe was his usual obliging self.
I used this tube to make a brass boiler - still going strong.
This is going to sound like a daft question but can you tell me why the grade of brass is important?
Thanks
BB
Edited to say - I have always found Joe to most helpful .
I am sure he would be able to tell you  the grade of brass if asked.
Edited By Billy Bean on 28/01/2018 18:50:07
Mike Crossfield28/01/2018 21:14:48
286 forum posts
36 photos
The grade matters because I will need to skim it after filling it with lead. Some grades of brass are chewy, and tear, so getting an attractive finish is very difficult. Guess I need to speak to the man at Maccmodels.
Billy Bean28/01/2018 21:25:22
174 forum posts
The tube Joe sent me polished up a treat - I just squared ends on lathe and then spun and polished - I have an older lathe just used for that purpose.
Sounds an interesting hobby - is there a reason why it is skimmed after filling with lead as opposed to skimming prior to filling ?
I quite understand why grade matters and thanks for explaining.
BB
roy entwistle28/01/2018 21:27:07
1716 forum posts
Mike I always filled my weights with lead shot. You used to be able to get it from gunsmiths but I'm not sure whether you still can
Roy
DMB29/01/2018 00:32:21
1585 forum posts
Roy,
If 12 bore cartridges no longer filled with lead shot, I wonder what on earth is used as a substitute?
Clive Hartland29/01/2018 08:49:37
2929 forum posts
41 photos
Steel shot or Bismuth. Barrels need to be marked for steel shot. Range is lowered for steel shot and most water shooting is now Bismuth shot. Lead kills birds by ingestion from dabbling in mud and/or being shot!
roy entwistle29/01/2018 09:31:42
1716 forum posts
Clive How does the weight of Bismuth shot compare with lead ? ( Just out of curiosity these days )
Roy
John Haine29/01/2018 10:01:02
5563 forum posts
322 photos
Ditto, why would you need to skim it? Shouldn't get lead on the outside if poured carefully; it will probably tarnish but surely that can be removed by polishing?
Mike Crossfield29/01/2018 13:00:42
286 forum posts
36 photos
I like to see a finely turned finish on weights and pendulums, so need a suitable grade of brass.
Mike Crossfield29/01/2018 13:02:08
286 forum posts
36 photos
Also takes care of any minor surface imperfections.
