How to set up?
Brian H | 01/01/2018 16:05:46 |
![]() 2312 forum posts 112 photos | Can anyone suggest how to set up endmills and slot drills so that the cutting edges are square to the grinding wheel? I suppose it could be done by eye but there must be a better way. Brian |
ASF | 01/01/2018 16:14:56 |
131 forum posts 12 photos | Use a height gauge to find height then half the diameter down. Put edge of cutter on that height. Also look at |
Neil Wyatt | 01/01/2018 16:39:57 |
![]() 19226 forum posts 749 photos 86 articles | "is someone out there implying that us hobbyists are cheap bas..." |
John Haine | 01/01/2018 16:46:51 |
5563 forum posts 322 photos | From what I could work out on how he set the cutter perpendicular to one of the long edges, you could use the little optical aid that I made a while back, here shown in use setting a cutter in an "Acute" tool holder. It's basically a rectangle or perspex bolted to the face of a short length of key steel, after having lines scribed on it at right angles to each other at appropriate places. You hold it against the end face of the cutter and align the edges of the latter to the appropriate lines. The eye is very sensitive to alignment of lines so it can be very accurate, using a magnifier if necessary. |
Brian H | 01/01/2018 16:51:59 |
![]() 2312 forum posts 112 photos | Posted by Neil Wyatt on 01/01/2018 16:39:57:
"is someone out there implying that us hobbyists are cheap bas..." Surely he's right Neil, at least about some of us! Anyway, very grateful for the suggestions, all I need to do now is try it; my Union T&C grinder is all set up with my Stevenson fixture complete with one of the ER32 collets that Santa brought, now to have a grind. Brian |
Robbo | 01/01/2018 20:46:57 |
1504 forum posts 142 photos | Posted by Neil Wyatt on 01/01/2018 16:39:57:
"is someone out there implying that us hobbyists are cheap bas..." All those I've met are as tight as a duck's wotsit |
Nick Hulme | 01/01/2018 21:59:07 |
750 forum posts 37 photos | Posted by Neil Wyatt on 01/01/2018 16:39:57:
"is someone out there implying that us hobbyists are cheap bas..." Well maybe, but not the ones who work at 12" to the foot though |
Brian H | 02/01/2018 16:56:55 |
![]() 2312 forum posts 112 photos | The video was quite good but confused by the use of a high helix 3 flute cutter. It would have been much more helpful if he had stuck with the 2 flute conventional slot drill. Even so, I've managed to sharpen a 2 flute slot drill satisfactorily, not bad for the first time. Brian |
Howard Lewis | 05/01/2018 17:22:28 |
7227 forum posts 21 photos | "Not tight; just careful, y'ken" Howard |
