Neil Wyatt | 07/12/2017 16:02:54 |
![]() 19226 forum posts 749 photos 86 articles | I have been getting increasingly annoyed by poor print quality for the last week or two. The solution was a nozzle change, I should have realised sooner! The need for it was apparent as soon as I held the old one next to a new one... Previously I have had the bore of the nozzle wear greatly oversize. This time, although the bore is only slightly enlarged the tip is greatly worn back and this has caused the prints to lose definition. Looking at these pics I'm surprised I go a recognisable print at all! |
jimmy b | 07/12/2017 16:46:06 |
![]() 857 forum posts 45 photos | I found this out when I serviced mine. Cost so little too!
jim |
Andrew Tinsley | 07/12/2017 16:51:38 |
1817 forum posts 2 photos | Hello Neil, What sort of printer was it? My laser printer has gone all streaky in vertical lines and colour rendering differs from RHS to LHS. Goodness knows how laser printers work! Andrew. |
David Standing 1 | 07/12/2017 17:18:00 |
1297 forum posts 50 photos | Posted by Andrew Tinsley on 07/12/2017 16:51:38:
Andrew I believe Neil is referring to his 3D printer.....several clues.
Edited By David Standing 1 on 07/12/2017 17:18:50 |
Anna 1 | 07/12/2017 17:43:38 |
![]() 72 forum posts 3 photos | Neil, Just out of curiosity are 3D printer nozzles sapphire, or just as they appear brass or bronze? regards ANNA |
Neil Wyatt | 07/12/2017 21:40:56 |
![]() 19226 forum posts 749 photos 86 articles | Ordinary ones are just brass, which is why they are about 11p each... You can get longer-lived stainless steel ones and no doubt carbide ones Neil |
Neil Wyatt | 07/12/2017 21:43:01 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Andrew Tinsley on 07/12/2017 16:51:38:
Hello Neil, What sort of printer was it? My laser printer has gone all streaky in vertical lines and colour rendering differs from RHS to LHS. Goodness knows how laser printers work! Andrew. A 3D printer Sounds like your laser might need a new drum, if it has a separate drum and toner cartridge. A partial cure may be removing the toner cartidge and shaking it, if the toner is getting low. |
Anna 1 | 07/12/2017 22:18:33 |
![]() 72 forum posts 3 photos | Hi Neil thanks for info Regards Anna |
