Colin LLoyd | 22/10/2017 14:15:32 |
![]() 211 forum posts 18 photos | I noticed that you can buy magnetic swarf pickup tools online for anything from about £10 up to nearly £60. Being a parsimonious sort of guy - I couldn't see from their images why they cost so much. So I made one: 4 off 10mm dia x 10mm long neodymium magnets capable of 3.9kg lift = £8 (4 was minimum order at first4Magnets) 200mm length of 15mm OD FLOPLAST PE-X barrier pipe (general water piping) - had short length lying around - but about £1 per meter or less.I capped one end with a circular plastic cap super-glued on. 200mm coach-bolt - 35p from local shop. I used a 30mm circle of rubber with 15mm hole in middle to act as a barrier along the pipe. The magnet is so strong that the magnet and coach bolt thread end form a perfect bond. This combination is then just slipped into the tube. Swarf pickup is easy - withdrawing the coach bolt leaves most of the swarf behind and any left over is stopped by the rubber barrier - it then drops off. Another use is picking up any amount of ferrous objects - bolts, nuts, washers, etc - again withdrawing the coach bolt releases the objects. So for a cost of £2-50 - or £10 if I make 4 and give three away as Christmas presents (cheapskate that I am) - I have a tool that does the job even if not so elegant. |
norman valentine | 22/10/2017 15:55:32 |
280 forum posts 40 photos | Can you make a special one for me, I turn a lot of aluminium and it would be really useful. |
Neil Wyatt | 22/10/2017 16:30:05 |
![]() 19226 forum posts 749 photos 86 articles | Posted by norman valentine on 22/10/2017 15:55:32:
Can you make a special one for me, I turn a lot of aluminium and it would be really useful. Yes, but you will need to bathe your workshop in liquid nitrogen Neil |
Colin LLoyd | 23/10/2017 10:37:58 |
![]() 211 forum posts 18 photos | Neil - rather an obtuse comment - can you explain? My simple answer to Norman is magnets don't attract non-ferrous metals - but his comment may have been tongue-in-cheek. |
not done it yet | 23/10/2017 11:01:05 |
7517 forum posts 20 photos | I just use a strong magnet inside a deep(ish) plastic bin/tub/etc. Nothing fancy. |
mark costello 1 | 23/10/2017 17:18:11 |
![]() 800 forum posts 16 photos | Put a rare earth magnet on some bronze and see what happens. |
norman valentine | 23/10/2017 17:39:17 |
280 forum posts 40 photos | Of course it was tongue in cheek, that was why I used the winking emoji. Neil's reply was perfect, it needed no clarification. It made me do some research of my own. Have you tried dropping a neodymium magnet down the inside of a roll of aluminium foil? I have now, you learn something new every day.
not done it yet | 23/10/2017 23:15:48 |
7517 forum posts 20 photos | I used to get students to drop a steel slug down a piece of copper pipe and catch it, as it exited, with the same hand. Then substitute a neo magnet for the steel slug and show how easy it was to catch it! In simple terms, lines of magnetic field crossing a conductor induce a current which, in turn, produces a magnetic field which opposes that of the magnet (and defeats gravity a bit). B asics of motors and generators.
Colin LLoyd | 24/10/2017 11:21:15 |
![]() 211 forum posts 18 photos | Posted by Neil Wyatt on 22/10/2017 16:30:05:
Can you make a special one for me, I turn a lot of aluminium and it would be really useful. Yes, but you will need to bathe your workshop in liquid nitrogen Neil Yes sorry guys - I don't recognise emoji's - something to do with lack of monitor peripheral vision - it's a technical term. Still prefer to use the ancient art of words to indicate emotions. Also my scientific journal editors would not allow such items without a glossary at the beginning of the paper to effectively define these terms so that other researchers could test my observations that had emoji's alongside. |
Danny M2Z | 24/10/2017 11:29:37 |
![]() 963 forum posts 2 photos | Hi Colin. Great tool at decent cost saving. Well done! * Danny M * |
John McNamara | 24/10/2017 13:16:30 |
![]() 1377 forum posts 133 photos | Picking up non ferrous swarf, can it be done with eddy currents? I have been thinking on the question posed by Norman Valentine "Can you make a special one for me, I turn a lot of aluminium and it would be really useful." I remembered I had seen a video of scrap metal being separated using this quite commonly used industrial process. The following link points to various examples. A good DIY example OK so how do we make a hand tool that that uses the principle? Some sort of moving magnetic field. I know this is a way out concept! A perfect test of the diverse skills that are available on this forum. Regards
duncan webster | 24/10/2017 18:57:22 |
5307 forum posts 83 photos | I think if you put a non magnetic conductor in an alternating magnetic field you get repulsion, not attraction. |
norman valentine | 24/10/2017 19:39:53 |
280 forum posts 40 photos | Danny, I thought that it was a good idea but there is no harm in having a joke. I object to being called a muppet. |
John McNamara | 24/10/2017 23:09:50 |
![]() 1377 forum posts 133 photos | Repulsion or attraction does it matter? the main thing there a force, the question is how can we use that force to move the swarf particles?
Colin LLoyd | 25/10/2017 12:35:28 |
![]() 211 forum posts 18 photos | Posted by John McNamara on 24/10/2017 23:09:50:
How to use the force is the problem - attraction is easy to deal with but I can't see how you would easily operate a high speed magnetic rotor beneath a lathe or work-bench that could fling the non-ferrous metals in such a way that it didn't just create a mess somewhere else. |
John McNamara | 25/10/2017 13:10:11 |
![]() 1377 forum posts 133 photos | Hi Collin After I posted this question I did a little research: In the past I have seen a number of videos of DIY versions of so called rail guns, these however usually use sliding contacts and rather large capacitor banks to store enough energy to propel a projectile. Some appear to be quite dangerous. This is certainly not my intention here, I only want to move material at safe speeds. I then stumbled upon what are called coilguns, these do not use sliding contacts they are more like a stack of solenoids see the link below. From that link the following paragraph on non ferromagnetic projectiles "Some designs have non-ferromagnetic projectiles, of materials such as aluminum or copper, with the armature of the projectile acting as an electromagnet with internal current induced by pulses of the acceleration coils." They are inducing eddy currents in the material. So maybe there is a way to move non ferrous material slowly. To be absolutely clear I have no interest and will not participate in any conversation about moving anything but swarf, waste or any other low speed material moving use. |
Howard Lewis | 26/10/2017 18:42:33 |
7227 forum posts 21 photos | My versions use a cheap extending "stick" magnet inside a piece of either 15 mm, or 22mm copper tube, with a thinned down copper or brass disc soldered onto the end. Don't be like me and try to thin the end too much, otherwise you have to make the Mark 2 or even Mark 3 versions with thicker endplates!. Rapid withdarwal causes MOST of the ferrous swarf to fall off, when it hits the external rubber ring. (Some of the very fine particles still adhere; possibly for the reasons posted above?) Yes, very useful, saves my aged back from bending to retrieve dropped taps or hardware. Pity that it doesn't work for brass or Ali! Howard |
