Alan Gordon 4 | 29/09/2017 16:51:46 |
129 forum posts 13 photos | Hello Chaps, I need some advice, I have a Myford Super 7 but the tail stock does eject any tooling that i put in it . I stripped it down, cleaned and oiled but still it will not eject any tooling, nothing seemed out of place but the only way I can get a piece of tooling out is to "gently" tap it out ! Any ideas as to what is wrong would be greatly appreciated. Edited By Alan Gordon 4 on 29/09/2017 16:52:09 |
John Haine | 29/09/2017 16:53:46 |
5563 forum posts 322 photos | Do the tapers you are using have ejecting tangs on them?
Alan Gordon 4 | 29/09/2017 17:23:49 |
Hi Colin yes they do
Robert Butler | 29/09/2017 17:27:29 |
511 forum posts 6 photos | Dear Alan what do you mean by "tap it out"? Robert |
Alan Gordon 4 | 29/09/2017 17:35:00 |
129 forum posts 13 photos | Hi Robert For instance if I put a drill chuck in when I retreat it I have to give a small tap on the rear end of the chuck. It's only a very gentle tap and it realises ok. It's the same if I insert a revolving centre, but they will not eject automatically
Mike Crossfield | 29/09/2017 17:44:37 |
286 forum posts 36 photos |
Robert Are you quite sure you have a Super 7 tailstock, not an ML7 tailstock? The ML7 tailstock is not self-ejecting, and is open at the rear to allow for a drift to remove tooling. On a Super7 tailstock there is no access for "tapping out" MT2 tooling. Mike |
Alan Gordon 4 | 29/09/2017 18:02:18 |
129 forum posts 13 photos | Hi Robert, Sincere apology, The tooling I was trying does NOT have tangs as you suggested, To be fair the the drill chuck which does have a tang now ejects well ( it didnt before) so I guess the clean out I gave it worked ! However The rest of my tolling does not have these tangs so it look like I will have to invest in new MT2 arbours (with tangs) |
Michael Briggs | 29/09/2017 18:17:43 |
221 forum posts 12 photos | Hello Alan, you can buy screw in tangs for your arbours. **LINK** for example. Edited By Michael Briggs on 29/09/2017 18:18:28 |
Alan Gordon 4 | 29/09/2017 18:29:56 |
129 forum posts 13 photos | Thanks Guys For all your help and advice, Tangs ordered and problem solved |
Peter Tucker | 29/09/2017 18:54:26 |
185 forum posts | Hi Alan, I just use a piece of studding or a sawn off bolt. Peter |
