Col21 | 18/08/2017 17:35:48 |
18 forum posts 8 photos | What sort/shape should a cutter be boring out a copper coated bush in a milling machine. Was going to use a piece of 6mm hss. |
Nick_G | 18/08/2017 17:40:43 |
![]() 1808 forum posts 744 photos | . When you say coated. How thick is the coating and what is the base material under the coating.? I ask this as if it's not a very thick coating you may be able to get under it in the first pass. Are you also sure the bush is copper.? Nick |
David Standing 1 | 18/08/2017 17:42:33 |
1297 forum posts 50 photos | And, following on from Nick's post, are you sure it isn't an oilite bush? |
Col21 | 18/08/2017 17:54:14 |
18 forum posts 8 photos | It's a copper coated small end bush. I assume it'll be steel. Only got to remove about 0.4mm |
JasonB | 18/08/2017 17:56:36 |
![]() 25215 forum posts 3105 photos 1 articles | What size is the bore as that will determine what sort of tools will fit down the hole. Do you have a boring head? |
Col21 | 18/08/2017 18:15:48 |
18 forum posts 8 photos | 50mm bore by about 50mm deep. Yeah a vertex adjustable boring head which has 18mm holes |
JasonB | 18/08/2017 18:27:31 |
![]() 25215 forum posts 3105 photos 1 articles | Piece of 18mm bar drilled across at the end to take your 6mm HSS toolbit and then cross drilled for a grub screw say M5 to retain the bit. Should be nice and rigid which will help keep the bore parallel. |
Col21 | 18/08/2017 18:34:02 |
18 forum posts 8 photos | Thanks yeah that what I was thinking but what shape should I grind the cutter to get the best result. I.e. Large radius , relief and speed etc Edited By Rocketman on 18/08/2017 18:59:45 |
HOWARDT | 18/08/2017 18:38:50 |
1081 forum posts 39 photos | Is it a Glacier bush, or whatever they call themselves these days. They make steel backed bushes with various bearing materials. If it is then it can be pushed out and a replacement fitted, no matching necessary. |
JasonB | 18/08/2017 19:58:54 |
![]() 25215 forum posts 3105 photos 1 articles | Click the "988 photos" under my avitar and look in the "sketches" album, there are 4 photos there of a between ctrs boring bar numbered bb1-4 they show a suitable cutter profile. |
