John Slaven | 16/08/2017 19:42:56 |
![]() 27 forum posts 17 photos | Hi All, Need some advice here. Was going to start cleaning up a motorcycle rear disc on the face plate. When checking the alignment I found the outer face to be 0.13mm (5.1 Thou) out and the inner face to be 0.07mm (2.75 Thou) out. I have cleaned all the mating surfaces on the headstock and the face plate to rule out any dirt causing the misalignment. Should I take a small skim off the face plate to true it up? Any other advice would be welcome. Cheers the Noo John. |
Rik Shaw | 16/08/2017 19:53:26 |
![]() 1494 forum posts 403 photos | Yes John - a light skim on a (new?) faceplate would be quite normal to true it up. Make sure that the gibs on the cross slide are all adjusted correctly before starting the skim. Rik |
JasonB | 16/08/2017 19:53:41 |
![]() 25215 forum posts 3105 photos 1 articles | Quite usual to skim a new face plate. Mark it like the chuck so you can make sure it goes back on in the same position next time. |
Nick_G | 16/08/2017 20:06:11 |
![]() 1808 forum posts 744 photos | . I bought a 3rd party D1-3 faceplate of far east origin for my Boxford. It was waaaaaay off and needed from memory about 30 thou skimming. Nick |
John Slaven | 16/08/2017 20:14:29 |
![]() 27 forum posts 17 photos | Hi Rik, Jason and Nick, Thanks for the reply. I'll get it trued up with a wee skim. I've center punched the mounting flange next to the "0" mark on the headstock so I can re-align the face plate. Many thanks for your help. Cheers the Noo John. |
John Slaven | 16/08/2017 21:01:47 |
![]() 27 forum posts 17 photos | Hi All, Face plate true'd up and now spot on. Thanks for your help. Cheers the noo John |
