Maurice | 16/08/2017 15:39:24 |
469 forum posts 50 photos | Does anyone recognise the design of this boiler please? It is 13"high to the top of the barrel and 6 1/4" in diameter. I acquired it recently and wish to finish it, but I have several questions about it. First, there is no bush fitted for a safety valve to screw in. There is room for one in the top tube plate, but it would have to emerge through the smoke box lid. I assume the smokebox should be airtight, and this may be difficult to achieve. I suppose that the safety valve could be fitted on the side, at the top of the barrel, but I have never seen this. Secondly, what is the purpose of the large tube in the centre of the tube plate. it would seem to be either to accommodate a couple of hairpin superheaters fed from the steam fitting on the tube plate, or it is normally covered with a lid, and is used to scrape ashes into, and thence to the ash-pan, when cleaning the boiler, having removed the chimney. Lastly, how should the smokebox lid be fixed; should it be a semi-permanent fixture, only remover occasionally to what? I would like to finish it off with a full complement of fittings, but the absence of a drawing makes it a little problematical. Any suggestions will be welcome. |
Martin W | 16/08/2017 16:06:26 |
940 forum posts 30 photos | It may just be the way that the photo was taken but the soldering shown in your picture Vert Boiler 2 looks decidedly 'iffy' and looks as if it hasn't wetted the joint properly between the tube plate and the boiler shell. As I say it may just be the way the photo was shot but a closer examination might reveal more. Cheers |
JasonB | 16/08/2017 16:21:08 |
![]() 25215 forum posts 3105 photos 1 articles | Large tube could be to take a superheater Top comes off so you can sweep the tubes |
Maurice | 16/08/2017 16:49:18 |
469 forum posts 50 photos | I agree with Martin about the solder. I intend to faux it well and reheat it. I also agree with Jason about the superheater. I may have to make a new top as the one that came with it only has about a quarter of an inch parallel with which to fasten it down and seal it. Have to take a closer look and do some drawings. Thanks for the feed back gents. |
duncan webster | 16/08/2017 18:33:32 |
5307 forum posts 83 photos | Some vertical boilers (especially steam waggons) had a big flue down the middle so you coud fire them from the top, just lift a lid on the smokebox and tip coal down. There must have been a divider in the smokebox or it would have killed the draft. This one looks a bit small for that tho'. The normal firedoor would be used for getting rid of clinker etc. |
fizzy | 16/08/2017 20:24:41 |
![]() 1860 forum posts 121 photos | Is that not a safety valve tapped into the top tube plate in picture two? If you get proper stuck pm me and I will help you sort it out for free - I make boilers full time. If firing on coal you will need to get the steam blower right also (doesnt seem to be one?) |
