Sino SDS-2MS Dro problems
Does anyone know where I can get a manual for this Dro?
Mike Crossfield14/08/2017 13:59:24
286 forum posts
36 photos
I fitted a Sino SDS-2MS Dro to my mill last year. It's been very reliable and accurate, but I am having problems setting up the pcd hole pattern function. The Dro was supplied by Machine DRO, but came with a manual for a later model, SDS6. I was assured that this manual also covered the SDS2, but I have found that while most of the functions are the same, the data entry steps for some functions such as pcd don't work. Now I guess this could be a hardware fault, but before I go down that route I want to be quite sure I am following the correct set up steps for this model dro. Machine DRO can't supply the correct manual for some reason, and I've got nowhere trying to communicate with the manufacturer.
Does anyone know of a source of the correct manual, or if you have such a manual would you be willing to copy some pages for me?
Thanks
JasonB14/08/2017 14:23:50
May be the way you are entering the data, have a look at this recent thread about using the DRO there are two ways it can be done, either enter one more hole and have the finish as (start + 360) or enter exact number of holes and finish 360/n deg from start.
Edited By JasonB on 14/08/2017 14:24:12
Mike Crossfield14/08/2017 17:46:58
286 forum posts
36 photos
Jason
I should have explained the problem more clearly. It's not to do with the number of holes.The problem occurs when I try to enter the pitch circle diameter after entering the centre coordinates. The data usually displays with the decimal point in the wrong place, and I can see no way to edit. If I come out of pcd mode and start again it sometimes works correctly! I was hoping that the correct manual might show some step I am missing.
ian j14/08/2017 20:10:27
337 forum posts
371 photos
I had a problem with setting PCD details on my SINO SDS6-2V until I changed the count direction to:-
Y -Ve, table towards you
X -Ve, table moves to the left
Ian
Packmule15/08/2017 10:57:14
133 forum posts
6 photos
Here's a link for you .I found the video's very useful.
https://www.machine-dro.co.uk/videos
I had same problem and contacted Andy at machine -dro who pointed the way.
regards,
Bob
Clive Foster15/08/2017 13:46:22
3630 forum posts
128 photos
On my Sino SDS2MS the PCD and other advanced functions only work properly in metric units.
Some of the toys went from pram to, probably, geostationary orbit during the learning process until I twigged this!
Machine-DRO, or rather Allendale as they then were sent me their revised and translated version of the manual which was great improvement on the Chinglish but still not completely clear in places. Especially the PCD function. Plenty good enough for remind-me use when you've not used it for a while but not the best at expelling from nothing.
Clive.
Mike Crossfield15/08/2017 18:09:45
286 forum posts
36 photos
Ian. I can't see how the polarity of the axes would affect the particular problem I'm having, but thanks for the suggestion.
Bob/Clive
I've gone through the videos and tried operating in metric mode only, but still get funnies. Some progress though.
Let me go through the steps and maybe you can explain what's happening.
- I move the table to the centre of the hole pattern and zero both axes
- I select pcd mode. X and y displays show 0.00, and other display shows CNTR POS
- I press enter and down arrow. Displays show last entered diameter, and DIA
- I enter, say, 10.0 for the required pattern diameter, expecting to overwrite the stored value,but the display shows 0.1, then 0.00 when I press enter !
This was where I was previously getting stuck. However, I have just found that if I press enter again, then 10.0 followed by enter everything works correctly.
I don't understand, but this sequence seems to work reliably every time.
Any suggestions?
Nick Hulme15/08/2017 18:27:52
750 forum posts
37 photos
Posted by Mike Crossfield on 15/08/2017 18:09:45:
Any suggestions?
Everything should just work, but consider that it's all software in there and it was written by people and you know what people are like
Packmule15/08/2017 19:38:52
133 forum posts
6 photos
Hi Mike ,
Just been in the workshop and still in the memory was the last PCD i did for a chimney saddle .
Centre poss 0.000 &0.000
down arrow PCD dia 60.00
down arrow number of holes 5
down arrow start angle 0.000
down arrow end angle 360.000
down arrow again for first hole
This gave 4 holes finishing back at No1
hope this helps
Bob
Mike Crossfield15/08/2017 19:47:21
286 forum posts
36 photos
Bob
I have no problems if I use the stored diameter value. The problem is when I try to overwrite it with a new value.
Clive Foster15/08/2017 20:17:02
3630 forum posts
128 photos
Interesting.
Mine doesn't retain any data after leaving the PCD routine. Always comes back with all zeros for most data calls except for diameter which merely show just a decimal point dot while waiting for new data. Think you can go round again if you don't leave the routine but its ages since I last did more than one off on a PCD job.
As I recall matters editing data has always been a bit problematic so my habit is to exit the PCD routine and start over. No idea if thats really necessary but its what I found works so am not going to fix it.
Mine is quite old tho' maybe 2005, 2006 vintage so no doubt the bits behind the panel have changed over the years.
Clive.
Alan Gordon 413/06/2019 11:21:59
129 forum posts
13 photos
Hello Mike
I wonder if you were to resolve the this issue with your SDS2MS ? I have been having the exact same issue with mine. I have had it for many years but recently decided to try and put it to greater use and like you when I tried to carry PCD function my problems started. Like you Allendale sent me the SDS 6 manual but this was of no help. I am talking to Allendale but so far they have not been able to offer a solution.
Kind regards
Alan Gordon
Mike Crossfield13/06/2019 14:34:07
286 forum posts
36 photos
Alan
Yes, I did sort it out. What I found was that when you enter the PCD Function and the CT POS display comes up you MUST enter values for X and Y, even if they are both zero and the display is already showing zero. You can’t just press enter and move on to the next setting. To be fair it does show this in the manual (steps 3 and 4 in the version I have), but it wasn’t clear - to me at least - that you need to enter zero if the display is already showing zero.
Hope this works for you too.
