lifting machine
James Steele | 24/07/2017 17:31:07 |
12 forum posts | HI all looking for help I finally decided on my new milling machine its a waro gh universal square column.My problem is that i am not sure where to put the straps of the engine hoist.Also i am not sure if i have enough room for a hoist to fit in my shed.If i need to dismantle the mill is it straight forward taking the head off.Any ideas or tips would be greatly appreciated thanks Jimmy
Oldiron | 24/07/2017 18:55:27 |
1193 forum posts 59 photos | Hi Jimmy. Usually the user guides that come with heavy machinery have lifting instructs in them. If not contact Warco direct they will be happy to tell where to lift it. Not too sure on removing the head but usually running it right down to the bottom of the ways should get it below the top of the column and give minimum height. Then its probably easier to remove the motor if it is above the column top. The thing to remember is if you take the head off do you have the height to put it back on when its on the bench or its stand. regards Gary
I.M. OUTAHERE | 24/07/2017 19:30:26 |
1468 forum posts 3 photos | Basically the same as my hafco mill , wind the y axis all the way in lower the head as far as possible and sling it up aroung the head swivel bracket as close to the column as you can get it , use the x axis movement to balance it up so it hangs straight If you want decent manuals for it try thry the grizzly website . |
Bill Davies 2 | 24/07/2017 21:14:46 |
357 forum posts 13 photos | Hi, James. After doing what XD says above, I lifted mine with flat fabric straps around the circular part between the head and the vertical slide, where the protractor strip is mounted. I left the motor in place. I had my son to hand to stop the mill from swinging about on the cable, and carefully positioned it on a wooden stand. Take it easy, it is very heavy, although perhaps less intimidating to those already accustomed to moving machines or engines. Regards, Bill |
James Steele | 24/07/2017 21:20:17 |
12 forum posts | Thanks for all the help I will get a friend to help and give it a go tomorrow Jimmy |
SillyOldDuffer | 25/07/2017 08:54:31 |
10668 forum posts 2415 photos | Posted by James Steele on 24/07/2017 17:31:07:
... Also i am not sure if i have enough room for a hoist to fit in my shed. thanks Jimmy
When I bought a bigger lathe I found that I'd miscalculated by 200mm the space needed to maneuver the engine crane plus lathe inside my garage. As a result it was difficult to get the lathe up against the wall as planned. Needing time to think, I plonked the lathe down at right-angles to the wall instead. By happy accident this position gave much better access for gear changes, so I've left it where it is. However, I did get useful suggestions from the forum about moving heavy objects in tight spaces: basically some combination of rollers, levers, wooden blocks, and perhaps a jack. The rollers can be lengths of pipe. Perhaps someone who has actually done it could provide more detail. I don't believe it's difficult, just sweaty and time-consuming compared with using a crane. Dave
Edited By SillyOldDuffer on 25/07/2017 08:55:36 |
James Steele | 25/07/2017 20:38:18 |
12 forum posts | Thanks or all the suggestions I ended up dismantling the mill into managable pieces and my friend and i got it installed tomorrow i will tram it in and make some chips Jimmy |
