Here is a list of all the postings James Steele has made in our forums. Click on a thread name to jump to the thread.
Thread: 9x20 Lathe Parts |
20/03/2018 21:23:33 |
Thanks John MY lathe is from chester machine tools and has a 3mm pitch lead screw your chart might be what im looking for thanks Jimmy |
19/03/2018 15:38:21 |
Hi can any one help me i have a 9x20 lathe with a metric lead screw I need to cut a imperial thread and i was wondering does anybody have a imperial change gear chart for the metric lathe so that i can get the correct gear train set up to cut imperial gears Thanks Jimmy |
Thread: arceurotrade DRO |
06/08/2017 22:17:03 |
Mine is the same as yours Dave I will just have to ignore it to thanks Jimmy |
06/08/2017 19:02:48 |
Hi all i finally got the warco GH Universal Mill set up and ready to go I fitted it with a set of DRO`s from arceurotrade and i am happy with them i was wondering if there is any way of turning off the fractions when it is set on the inch setting Thanks Jimmy
Thread: GH Universal |
25/07/2017 20:38:18 |
Thanks or all the suggestions I ended up dismantling the mill into managable pieces and my friend and i got it installed tomorrow i will tram it in and make some chips Jimmy |
24/07/2017 21:20:17 |
Thanks for all the help I will get a friend to help and give it a go tomorrow Jimmy |
24/07/2017 17:31:07 |
HI all looking for help I finally decided on my new milling machine its a waro gh universal square column.My problem is that i am not sure where to put the straps of the engine hoist.Also i am not sure if i have enough room for a hoist to fit in my shed.If i need to dismantle the mill is it straight forward taking the head off.Any ideas or tips would be greatly appreciated thanks Jimmy
Thread: getting a mill over to Ireland |
09/07/2017 16:17:53 |
I dont have a van and to hire one only puts the price of the mill up and does any one know of a good company that will deliver to Ireland Thanks Jimmy |
09/07/2017 15:54:25 |
HI Guy`s I have been looking at the Warco wm16 or the wm18 mill they seem a good mill for a beginner.The other day i saw a picture of a Boxford vm30 i really liked the look of these big old solid cast iron lumps the only problem is that they cant be found in Ireland.I have seen a couple on E-bay but don`t have a clue on how i would get it over to me in Ireland.does any one know of a way or would i be better off sticking with my first choice Thanks Jimmy |
Thread: Hello from Ireland |
05/07/2017 20:06:11 |
I have read a few comments about the wm16 mill and how the hi low gear can give trouble I see Warco do a wm16B for £250 more.its belt drive and has a brushless motor would you think this would be a better purchase
Jimmy |
05/07/2017 19:58:20 |
Hi Dave I live in Waterford |
05/07/2017 11:28:26 |
Hi I am a new member from Ireland i am currently looking at a warco wm16 I am limited to space so this looks a good size machine looking forward to picking a few brains about setting up and fitting a DRO. i was given a 5" swivel base vice is this to big or should I get a 4" vice. |
