Making bourdon tubes from pressure gauges
Mike Robinson 317/07/2017 21:25:57
3 forum posts
I would like to restore two oil pressure gauges for a 1912 car.
At this time the gauge needle was usually connected directly to the bourdon tube, ie no gearing. This meant the tube had to be very thin. Both my gauges came with broken tubes.
The editor of MEW tells me that the making of bourdon tubes for model engines was a topic on the web site a while back.
I have failed to locate the thread using the web site's search engine.
Can anyone please help?
Mike Robinson
JasonB18/07/2017 07:26:00
Quite possibly this thread but we have talked about them before. If you look down the home page there is a google search box, if you type bourdon into that you will get some of the other threads too.
J
duncan webster21/07/2017 15:56:21
5307 forum posts
83 photos
Making bourdon gauges was covered by Henry Wood in ME recently, and a different way is described in Kozo Hiraoka's book on the Heisler (and possibly the Shay and Climax)
Ian S C22/07/2017 10:56:30
7468 forum posts
230 photos
I remember a description of of one method in ME many years back. A suitable bit of brass rod is drilled through. A steel mandrel is turned to size, and while still in the lathe the bit of brass is fitted on this, and the out side of the rod is bought down to a suitable wall thickness(I don't remember the dimensions), the tube is then removed, and a bit of shim metal is put in the bore, and the tube flattened over it by drawing it between your thumb and a bit of round bar, this will cause the tube to bend in a curve, take the shim out.
Ian S C
Mike Robinson 324/07/2017 20:50:51
3 forum posts
Thanks Jason, Duncan and Ian for your prompt responses.
The Jan/Feb copy of Model Engineer that I ordered arrived this morning. The article in it gave me more confidence in the reliability of the soldered shim method than the posts on the thread Jason suggested.
However, I do fancy trying the method Ian describes. The wall thickness obtained on my Boxford may be an issue!
Regards, Mike
