19 TPI
Screwcutting 19 TPI on Boxford AUD with Norton Box
Speedy Builder510/07/2017 14:40:24
2878 forum posts
248 photos
It must be on this site some where, but how do I cut a 19TPI thread. The Norton box gives 18 and 20, but annoyingly not 19 for 3/8 BSP threads.
BobH
ASF10/07/2017 14:52:15
131 forum posts
12 photos
Not going to help you, but on my Norton box it sits right between 18 and 20
dont know
JasonB10/07/2017 15:02:34
Play about with the gears between the spindle and gearbox input, don't really know what you have on te Boxford so can't help much more than that
Andrew Johnston10/07/2017 15:08:25
7061 forum posts
719 photos
You'll either have to tweak the gearbox drive train in the ratio 18/19, or 20/19. Alternatively, if you're near Cambridge come and borrow my lathe.
Chris Evans 610/07/2017 15:22:55
2156 forum posts
I suppose the Boxford is very similar to a South Bend lathe I used to own. When faced with cutting 19 TPI I used 20 TPI cut a bit loose as most pipe fittings are short I got away with it, plus I have dies up to 1/2" BSP to correct things. My newer lathe does do 19 TPI.
Clive Foster10/07/2017 15:29:43
3630 forum posts
128 photos
If your lathe has 28 tpi on the gearbox easiest way is to double the size of the stud gear or halve the size of the gearbox input gear. For a SouthBend 9" I think doubling the stud (input) gear size is the recommended way as the gear required is one of the standard set for a non-gearbox version. Also part of the conversion set for metric threads.
Clive.
JasonB10/07/2017 15:34:59
Clive would that not give 14tpi.
Might works if the box has an unusual 38tpi option
Edited By JasonB on 10/07/2017 15:35:37
John Haine10/07/2017 15:35:03
5563 forum posts
322 photos
Posted by Clive Foster on 10/07/2017 15:29:43:
Clive.
Um, 38 tpi?
Clive Brown 110/07/2017 16:31:21
1050 forum posts
56 photos
For a Boxford, if you happen to have either a 54 or a 60t change-wheel, replacing the 56t input gear will give 19.28tpi by setting to 20 or 18 tpi on the 'box.
That's been adequate for me for short lengths of thread.
Someone is selling 38t Boxford change-wheels, made of plastic, on Ebay, that would be a way to be spot-on.
Clive Foster10/07/2017 16:48:03
3630 forum posts
128 photos
Ooops. Need new glasses. John and Jason are right. Sorry I mis-read my reference.
Clive Brown has the answer. 38 tooth gear on gearbox input with standard 20 tooth stud gear with 28 TPI setting on the gearbox gives 19 tpi.
Speedy Builder510/07/2017 18:38:27
2878 forum posts
248 photos
Thanks Clive and others, Yes, I have a 54 and a 60, so 19.28 tip would be good enough. Thanks for the offer Andrew, could you pick me up from out local airport - SW France ? Joking apart, thanks everyone.
BobH
Brian Wood10/07/2017 19:26:30
2742 forum posts
39 photos
Hello Speedy,
​Stud gear 20, screw gear 38 and gearbox set for 28tpi will give you 19tpi exactly
​Brian
Speedy Builder510/07/2017 21:14:30
2878 forum posts
248 photos
Thanks Brian - I just need a 38 Tooth cog !
Bob
Bazyle10/07/2017 21:42:10
6956 forum posts
229 photos
Make yourself a 19t by filing the teeth. Changewheels do not need to be very precise for making fixings, only when you are making a new leadscrew for another lathe.
Brian Wood11/07/2017 09:31:41
2742 forum posts
39 photos
Hello again Bob,
​I like a challenge! I've worked out some more gearings for you without knowing really what you have in the way of change wheels. You've already mentioned a 54 and 60 and I assume you have the standard 56 wheel
For 54 wheel as screw gear, with 16 as stud gear and 16tpi set in the gearbox you get 0.05185 inch pitch [19.29tpi]
For 56 wheel, 24 as stud gear and 23tpi on gearbox you get 0.05219 inch pitch [19.16]
and for 25 stud gear and 24tpi on gearbox you get 0.05208 inch pitch [19.2 tpi]
​For 60 as screw gear, 36 as stud gear and 32tpi on gearbox you get0.05249 inch pitch [19.05tpi]
Some options for you
​Regards Brian
