Lee Goulding | 25/06/2017 18:34:29 |
123 forum posts 19 photos |
Hi All Me again.. I've just been stripping and cleaning up the tail stock and Apron Gear Assemply and noticed that the diagram in the manual has a washer 07/010 which on my lathe is not there instead there's a bearing!! And also there no EPL 19 waved washer between the handle and the dial gauge Thanks |
David Standing 1 | 25/06/2017 20:53:58 |
1297 forum posts 50 photos | Well then Lee, you're going to have to order them from Boxford. PS - you're gonna have a heart attack if you're not careful |
Lee Goulding | 26/06/2017 08:45:19 |
123 forum posts 19 photos | tell me about it.. loving it though in my new man cave.. |
Lee Goulding | 26/06/2017 08:46:35 |
123 forum posts 19 photos | would you suggest removing the bearing David and replace with the brass washer thats listed in the manual? Thanks |
David Standing 1 | 26/06/2017 08:56:06 |
1297 forum posts 50 photos | Lee If it works, I'd always stay as the original setup. Pictures of man cave required......... Edited By David Standing 1 on 26/06/2017 08:56:25 |
Lee Goulding | 26/06/2017 09:07:46 |
123 forum posts 19 photos | ok David thanks it just confused me when i took it apart then looked at the diagram and found the brass washer should be next in sequence but all i had was a bearing.
Theres defo two Wavey washers missing after the wheels which i think are a must to have so will get them
Thanks for your help.. |
Nick_G | 26/06/2017 09:29:17 |
![]() 1808 forum posts 744 photos | . My X10 has a bearing also. - I presume that this may be an undocumented modification by Boxford. My advice would be clean it, relube it and pop it back leaving well alone.
Nick |
Lee Goulding | 26/06/2017 09:56:30 |
Hi Nick I can confirm after speaking with Boxford that dependent on age it is a change that is on some machines and the manual is outdated so bearings are in place of some documented washers etc Thanks for the advice as always appreciated |
Lee Goulding | 26/06/2017 22:14:09 |
123 forum posts 19 photos | Hi All Update!! Lathe now running with inverter and control but as you can hear from the video clip there's a whistle coming from the motor when I increase the speed.. The electrician used SY screamed cable about 1 metre Any idea how to cure this
Thanks Edited By Lee Goulding on 26/06/2017 22:17:08 |
David Standing 1 | 26/06/2017 22:31:56 |
1297 forum posts 50 photos | Lee Did he ground the cable shield at one end, or both? |
Lee Goulding | 26/06/2017 22:42:34 |
123 forum posts 19 photos | Hi David Wil let you know when he gets back to me as I'm not sure Thanks |
Lee Goulding | 27/06/2017 09:24:25 |
123 forum posts 19 photos | Hi David Only one end was ground Thanks |
David Standing 1 | 27/06/2017 10:06:09 |
1297 forum posts 50 photos | Lee Then for starters try grounding both ends, in case that cures it |
David Standing 1 | 27/06/2017 10:26:48 |
1297 forum posts 50 photos | And if that doesn't work, despite the shielding, you may want to try moving the inverter a bit further away if you have enough slack cable. |
mark smith 20 | 27/06/2017 10:27:37 |
682 forum posts 337 photos | My Alexander mill inverter makes that sort of noise(high pitched whine) as well when it reaches speed. I think i only grounded one end of the s.y cable. I dont have a remote pendant on it as yet so just using the inverter controls directly. Edited By mark smith 20 on 27/06/2017 10:28:50 |
Lee Goulding | 27/06/2017 10:47:46 |
123 forum posts 19 photos | Hi David Thanks for that and will try both ends and the inverter is about a metre away from the motor as I was told that the cable from the inverter to the motor should be around a metre Thanks |
Lee Goulding | 27/06/2017 10:49:50 |
Hi Mark Thanks for that and hopefully can get it running quite and will update with fix if and when it happens 👍 |
Neil Wyatt | 27/06/2017 19:03:54 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Lee Goulding on 26/06/2017 22:14:09:
The electrician used SY screamed cable about 1 metre You will always get noise from screamed cable, try getting some mute cable. Neil |
Neil Wyatt | 27/06/2017 19:06:37 |
![]() 19226 forum posts 749 photos 86 articles | More seriously the shielding or lack of it won't make the motor noisy, but if the inverter is set for a low carrier frequency that can make odd noises. you can reprogram some inverters to use a different waveform and reduce the noise, or at least make it less unpleasant. Neil |
Nick_G | 27/06/2017 19:37:45 |
![]() 1808 forum posts 744 photos | . Now don't get jumpy or panicky. ................................ Yet. But on that video it was not the motor noise. It just on the whole sounded a bit 'rumbly' somewhere than the one I have. Maybe the video audio or something as simple as the change gears having the incorrect spacing and want a tad of adjustment.
Nick |
