SILVER SOLDER
RICHARD GREEN 223/06/2017 12:45:02
329 forum posts
193 photos
Has anyone used " Silverflo 452 ",
How did it compare to " Easyflo No.2 "
Has it any limitations ?
Richard,
Keith Hale24/06/2017 07:56:44
334 forum posts
Silverflo 452 is a 45% silver cadmium free alloy with 2% tin. It will produce strong joints but it behaves nothing like easiflo 2. It has a higher melting point and is not as fluid. Like anyone else who struggles with a cadmium free alloy fit a larger burner.
Keith
Bob Stevenson24/06/2017 08:21:34
579 forum posts
7 photos
The trouble I had(have) is that 452 seems to have a melting point dangerously close to the melting point of the brass. For small workpieces this can be really difficult as there is a real chance of destroying the edges of the piece by having to use too much heat.
Keith Hale24/06/2017 16:33:28
334 forum posts
The silver solder melts at 640 - 680 deg C. Most brasses melt about 850 deg C.
Bob, in your case you have too much heat. Fit a smaller burner.
It will probably have a more focussed flame with which you can control the heat better and not melt the edges of small components. That is why Sievert have the range of burners that they do.
For the same reason, people buy a range of spanners not an adjustable one.
One size does not fit all !
Keith
RICHARD GREEN 229/06/2017 16:45:28
329 forum posts
193 photos
Had some Silverflo 452 delivered today,
just used 2 rods, absolutely lovely, just like Easyflo,
I used it on some heavy brass sections and some 15mm copper tube and fittings,
Used Easyflo flux, and plenty of heat, ( Oxy Propane ) , no problems at all.
Richard.
Bruce Ephgrave15/09/2017 18:16:38
3 forum posts
Hello,
Would like to know how to keep fillets neat.
Thanks,
Bruce.
Keith Hale16/09/2017 10:07:50
334 forum posts
Hello Bruce
Examine your joint design, heating technique and how and where the alloy is applied.
Remember to use the effect of capillary flow to create small, neat tidy joints.
I am reliably informed that a new book covering this aspect is being launched at the Midlands Exhibition on the CuP Alloys stand or why not just come and talk to us.
Keith
Circlip16/09/2017 15:54:46
1723 forum posts
Second plug Keith, how much is the book going to cost?
Regards Ian.
